Moki 215 with extra's
Engine is basically new and not flown. Bench run and dialed in in cool weather. The engine is equipped with the Kunkel Turbulator installed between the engine and the carb. The vanes in the turbulator have been adjusted so that all 5 cylinders are running within 5 to 10 degrees of each other resulting in a fine smooth running engine. A new APS Powerfuel 380 RX is included. (The programmable one) Also a voltage regulator is included set to 5.5 volts so that the ignition module will have the exact correct voltage supplied to it. Also carb throttle and choke arms are supplied as well as the prop washer and bolts of course. The shipping mount is present but I do not have the original box. I regret selling this engine but I do have two others! A complete package even with an extra pushrod.
Price reduced to $2900.00
Price lowered to $2900.00 but no lower!
