T-14 Armata, scale 1/16 (3D printed - unassembled kit)
Hi,
have this unassembled 3D printed T-14 Armata for sale. Printed with ASA, PET(G) (only the biggest parts), Nylon, SLA resin. Here you can see pictures of this kit: https://photos.app.goo.gl/UzXsPZR2rFtAbJkn6 Video of the assembled vehicle: There is about 330 parts + tracks (3D printed tracks included) Not including any hardware.3D printed parts only. - compatible with a large number of gearboxes with 23mm and 59mm shafts (recommending 59mm) - integrated tracks tensioner - possibility of using aftermarket tracks (for T-90, 3 pieces of tracks are needed) - rims of the wheels and fender aprons made of "rubber" - main switch under the functional commanders hatch - functional headlamps - bearings on every important place - every screw has its own nut. there is no plastic screw thread. - a place for a PFV camera under the functional cover - functional service hatch on the turret - the turret rotates by 360° - the machinegun turret rotates by 360° - servo controlled cannon (with recoil) - space for IR diode next to the cannon - possible to deliver with an alternate machinegun turret with built-in HL IR receiver - 3D printed suspensions system, printed with Nylon.Sufficient for riding on simple terrain.Higly recommending to replace suspensions and tracks with some full steel alternative, if you want to enjoy riding in the hard terrain.Armata is big and have big weight for the plastic tank. I have an Assembly guide for this, but its only in Slovak language. Guaranted full technical support and access to the spare parts. Here is a buildthread of tank, builded with the same kit: https://www.rctankwarfare.co.uk/foru...9&hilit=armata |
