Retracts Robart struts wheels brakes gear set Turbinator
Air retract set for Turbinator or equivalent.
Tires are hard rubber. The main tires measure 3 inches and the nose measures 2 1/2 inches. There's nose strut measures 9 1/2 inches long from where the retract mounts, to the outer edge of the tire. The main struts measure 8 inches from where the retracts mount to the outer edge of the tires. All in good working order just needs a good cleaning. |
