Proboat UL19
I have lost access to my pond and must sell my hydroplane Proboat UL-19 :(:(:(
This is an awesome boat and the most stable I've ever had. Even in less than smooth water it stays stuck to the surface even at high speeds. And the inboard daggerboard really holds it in the turns( clockwise racing). From the photos you will notice I have upgraded this boat to have two separate water supplies( one for the motor, which is stock, and one for the ESC). Even after 4-5 minute runs , temps are115-150 degrees. ( even less on 4s) This thing will do 55+ mph easy. I had just ordered a Dasboata prop too!! ( $80). I have two other props as well, but the dasboata is awesome. I have seal tape , although its not really needed( compartment stays pretty dry. ). I have 3 sets of batteries for it also. I ran a 4s and a 6s set up.1 set is 4s and 2 sets are 6s. I'm also throwing in a little Jetjam boat. Both boats have transmitters. Also have a electronic temp monitor and flex shaft grease with gun If you are looking for some high speed fun on the water, then you won't find a better deal anywhere than this. Only used 6 times. Practically brand new, complete nothing else to buy. Complete package worth over $750.00. Sacrificing for $500.00. Please do not ask if I can take less. You are welcome to add up these components and you'll see. The boat alone is $425 new at its cheapest. |
