DeHavilland DH4 1/4 scale Balsa USA ARF / Just add RX and Battery to Fly
Balsa USA 1/ 4 Scale DeHavilland DH4 / Model is all built > wings fitted and incidence set , wings are finished with Silver Oretex , Fuselage is Painted , The Stab and Rudder can be removed on this model and the 7 R&D metal gear Hi torque servo are installed and they are hooked up with Pull > Pull on elv and Rudder . Ailerons are Hooked on wings and working > Model Weight at this point is 32.6 lbs RTF U need a RX and 2 - 5000 Ma 6 cell batterys to fly ,Has a Scorpion Motor and a Castle Hv ESC < Makes 5000 Watts on !2 cells , With a 23X10 Prop ,All parts are new to this Model
This is a Large Model 127 inch W Cash ONLY Pick Up ONLY CAN NOT SHIP THIS MODEL PICK UP AT MY LOCATION IN LYNCHBURG VA ONLY CASH ONLY |
