Lambert Kolibri T45
Newly service from Lambert. Previous owner had a bad start and all bearings etc are changed. The engine had 2-3 hours before service and got confirmed from Lambert as it is to be considered as new.
A really powerhouse of 440 gram Shipping approx 50$ Kolibri T45 Autostart The Kolibri T45Autosart is one of the world's smallest microturbines in series production for rc-model applications. Each turbine is individually tuned to guarantee a thrust of at least 4.5 kg under standard conditions. The advantages of the Kolibri are obvious - extremely low system weight à lower model weight, turbine can be mounted in the rear in most cases without a thrust tube à no additional costs - low fuel consumption à smaller tank volume à lower starting mass à shorter take off distance - Easy and quick start with gas à the turbine starts fully automatically and safely with gas and thus quickly reaches idle speed Technical specifications Diameter [mm]65 Systemweight [g]440 Length including Starter [mm]173 Fuel Consumption [ml]165 RPM range [rpm]65000 - 205000 Thrust [N]45 |
Kolibri T45
$ 1500. Shipping thank you let me know if it comes with pump gsu silinoid ecu wires ..
It is complete with wires, valves, ecu++ but unfortunately it will not be sold below what I am asking for.
Thanks Alf |
Alf,
Thank you for your response. I have a few additional questions as I am interested in this motor. 1. Can you send me additional photos of the GSU, Solenoid valve, ECU and the pump? I’d love to see those detailed photos 2. What type of payment do you accept? I.E. PayPal, etc 3. What is your method of international shipping? (I live in the United States) I.e. I prefer DHL or fedex 4. I want to confirm the total will be $1850 plus $50 for shipping. |
Hi again,
1. Can you send me additional photos of the GSU, Solenoid valve, ECU and the pump? I’d love to see those detailed photos I am back Sunday evening and will add some more pictures. 2. What type of payment do you accept? I.E. PayPal, etc Easiest is PayPal 1850 pluss fee 3. What is your method of international shipping? (I live in the United States) I.e. I prefer DHL or fedex I did previous use Norwegian Postal Service (Posten) I can check DHL but probably double or triple cost to the US. 4. I want to confirm the total will be $1850 plus $50 for shipping.[/QUOTE] 1850 for engine to me and fee on the buyer plus shipping. If bank transfer is cheaper or free that's fine . |
