Lucky-13 R/C Airplane, Bind & Fly, Incl batteries
Lucky13 ARF R/C Airplane, ready to bind-n-fly. Built, flown, dialed in, never been crashed. Only about a dozen flights on it, it's practically new. Clearing out some of my stuff to complete some other projects. This is a great intermediate trainer, with low wing and tail dragger configuration. It's flat bottom airfoil makes it a very stable bird. It can be set up as a gas or glow, but this one is all electric.
You can see a YouTube review at : The original info from the website where it was sold is still online here: http://207.126.49.130/estorelucky13.htm Here's what's in it: - XTRM 3520/06 Outrunner Motor Comes with radial mount and prop adapter. Similar to good sport .50-.61 size glow engine, great for for 3D (to 4lbs), sport & aerobatic aircraft weighing 3-6 lbs. SPECS: Voltage: 11.1V - 18.5V RPM/V: 800 Current: 18-40A (50A @ 60 sec) Power: 700W + Shaft Diameter: 5mm Weight: 7.05 oz. - Spin 60A Motor Speed Controller. Cowl modified for additional airflow and cooling. No heat at all with this motor at full power. - Batteries supplied: * New 5 cell 3500 mAh flight (radio) battery. I don't like the radio running on the same battery as the motor, just my personal peeve :-) * 2ea. Polyquest EnerLand PQ3700XP, 25C, 2C LiPo Battery, in series for 4 cell. * 1ea. Polyquest 30C, 4 cell, 3200 mAh Lipo. - Radio Installed: Spektrum AR7000 w/remote receiver - Servos Installed: * Spektrum DS821 Digital Servo - Rudder Pull-Pull * Spektrum DS821 Digital Servo - Elevator * 2ea. Spektrum DS821 Digital Servo - Ailerons - Spektrum Receiver Switch harness w/Charge Jack & Fuselage mount Well over $750 invested, selling for $400 |
