[Pre-Sale] Toyan FS-L200 Engine 2 Cylinder Four Stroke Nirto RC Engine
Features:
1, High Craftsmanship: Toyan FS-L200 engine is made of 2 series aluminum CNC with a more stable temperature coefficient. The compact and lightweight structure and multi-modular design provide better protection for subsequent upgrades. 2, Strong Performance: Asynchronous crankshaft structure is adopted, the operation is smoother, the acceleration response is sensitive, and the maximum speed is 16000 RPM. Displacement: 7.0cc (3.5cc*2) Output Power: 0.82ps.Short rocker arm design makes the valve switch more accurate. Longer crankshaft design, can be matched with front/reverse gearbox, suitable for RC model loading. 3, Unique Design: TOYAN FS-L200 is a brand-new platform specially developed for RC models. It is added to the engine design with red as the motion element. 4, Fuel: the fuel is consisting of : 20% castor oil, nitro-methane 5-30%, and the rest is methanol. 20-25% methanol content can be used as fuel. No need 100% pure methanol. Or you can buy the Methanol RC model directly from your local store. 5, Extra Accessories Needed for Operation: New Starting ESC module + 2 X Voltage regulator modules +Spark Plug + Oil Pipe + Oil Tank + 7.4v T-plug battery, These parts are required when start it, It is not included inside the pacakge. 6, Priority Gift Option for Many Applications: This Toyan FS-L200 engine can used on 1:10, 1:12, 1:14 scale car model or ship model and other equipment. Also, it can be used for classroom display as teaching Aids. Besides, it is ideal Gift for engine lovers. Specifications: Engine Model: Toyan FS-L200 Material: Metal + Plastic Speed: 2800-16000rpm Displacement: 7.0cc (3.5cc*2) Output Power: 0.82ps horsepower Cylinder Diameter: 17.0mm Piston Diameter: 16.62mm Product Dimensions: 5.95 x 4.5 x 8.44cm Product Weight: 590g Package Dimensions: 12 x 10 x 10cm Package Weight: 1300g Packing: Graphic Carton Please notice this Toyan FS-L200 is Pre-sale model, the shipping date will be around July,20th. Any questions, please contact with our service team at : [email protected] . Thanks! |
Toyan FS_L200 engine.
I am interested in your engine, will you send to Australia and how much to ship the engine? Peter.
