[Pre-Sale] Toyan Engine FS-S100AT Transparent Nitro-Methanol Gasoline RC Engine
Features:
1, 5th Anniversary Edition: Transparent Version, you can see its small "heart" with powerful power. 2, Fuel: gasoline / Nitro-methanol can be used. If you use it with gasoline and want to correct it to methanol, you have to adjust the oil needle. no other adjustment required. 3, Extra Accessories Needed for Operation:CDI, ESC Starting Module, 2 x 7.4v battery, Oil Tank, Oil Tube. 4, Priority Gift Option for Many Applications : This 4 stroke rc engine can used on 1:10, 1:12, 1:14 scale car model or ship model and other equipment. Also, it can be used for classroom display as teaching Aids. Besides, it is ideal Gift for engine lovers. 5, Using Tips: There is a position which you can connect CDI directly. 2 battery is for power supplying to CDI and Starting Module. Specifications: Model Name: Toyan Engine FS-S100AT Material: Metal + Plastic Speed: 3500-8500rpm Displacement: 3.5cc Output Power: 0.5ps Cylinder Diameter: 17.0mm Piston Diameter: 16.6mm Product Weight: 900g Package Dimensions: 12 x 10 x 10cm Package Weight: 1000g Packing: Graphic Carton |
