ESM Chance Vought F-4U Corsair 74" (NEWLY REDUCED)
NEWLY REDUCED ASKING PRICE... A spectacular buy here! Prefer local pickup
Also listed in RC Groups and Flying Giants.. https://www.rcgroups.com/forums/show...WLY-REDUCED%29 Newly finished, static tested, includes stands, air pump and fuel dot fill chuck. New Lithium ION and NiMH Packs. Never flown, never started. Includes all instructions/notes/suggestions. All up weight @ 17.7 lbs, beautiful bird. Over $3000 Invested. o Spektrum AR9000 DSM2 Rx o 26CC RCGF Gasoline Engine o Dubro 16oz Fuel Tank o 16x8 Master Airscrew 3 Blade Prop o Bullet Nose Spinner Hub o ESM Pneumatic Retracts o Tam Jets Gear Failsafe System o Robart Fittings, Canister, Air Lines, Etc o x7 Hitec HS-5645MG Digital Servos (AILE, ELEV, RUDD & FLAP) o x1 Hitec HS-5625MG (Retract Servo) o x1 Hitec HS-225MG (THRO) o Upgraded Dubro Control Linkage o Emcotec A11050 DPSI Micro Dual-Bat 5.5v/5.9v Regulator/Magnetic Switch o x2 ProModeler 7.4v 1500 mah Li-Ion Rx Packs o x1 Onyx 6v 2000 mah NiMH Ignition Pack o Dynamic Balsa Custom Cockpit $1,800 with stands OBO |
