Aquacraft Supervee 27 Nitro Boat
This boat was used maybe 4 or 5 times before moving from a lake area. It is in excellent condition, comes with 27" Boat,
Boat Stand, Decals, Radio. and one extra prop. General Description of Aquacraft SuperVee 27 It's the streamlined design that has captured the attention of boat racers everywhere... equipped with an .18-sized marine engine that's all about nitro power and performance! The SuperVee 27 Nitro is designed for all-out speed and maneuverability, but it's easy enough for even beginners to operate. And being ready-to-run means you'll be out on the water just minutes after taking it out of the box! Equipped with High-Performance GrimRacer hardware! An integral part of the AquaCraft line, GrimRacer parts and accessories are designed with one goal in mind: to maximize your boat's performance potential. Michael (Grimracer) Zaborowski has drawn upon his extensive and highly successful R/C racing experience to engineer equipment that meets - and exceeds - the highest quality standards. It truly is "Created BY boat racers, FOR boat modelers". Features: Surface Drive Adjustable Strut Assembly: The GrimRacer Surface Drive strut assembly is made of machined aluminum, with a .150" flex drive cable and a 3/16" prop shaft that allows for unlimited prop selection. Deep-water Rudder: The CNC-machined aluminum deep-water rudder offers maximum strength with minimum weight. Water Pickup: A GrimRacer water pickup mounted on the transom channels water cooling to the engine and header. Trim Plates: The mirror finish on the GrimRacer FE trim plates not only looks sharp, it resists rust - and because the plates are stainless steel, they won't flex upon contact with the water. The adjustable turn fin assemblies are made of aluminum and blue anodized. Cowl Lock System: Boasting the durability of stainless and spring steel, the Cowl Lock system is a quick, easy and convenient method for attaching and removing the hatch - with no loose parts to misplace. AquaCraft .18 Marine Engine: Water-cooled for top performance and equipped with a recoil unit for easy starting, the AquaCraft .18 marine engine relies on true ABC construction and dual bearings for smooth, dependable power. A tuned pipe and header are included. Engine Mount: A sturdy, blue-anodized engine mount effectively isolates the vibration typically created in nitro boats. Waterproof Radio Box: On-board gear and the battery stay high and dry inside this molded waterproof radio box. The lid removes quickly with living hinges. Fuel Tank: The easy-access fuel tank has a screw-on lid, eliminating the need for a fuel pump. Easy enough for beginners - fast enough for the experienced racer! Completely assembled and ready for action in just minutes! Specifications: Length: 27" (686mm) Width: 8.13" (205mm) Height: 5.5" (140mm) RTR Weight (w/o batteries): 3.4 lb (1545 g) Engine: AquaCraft .18 engine with tuned pipe (included) Radio: AquaCraft 2-channel radio (included) |
