Sequence 120
I have 2 like new sequence 120's both with ys140 engines and hatori pipe tuned exhaust pipes. 1 has 30 flights the other had about 4. Both have truturn spinners and apc props. 725 and 775 dollars respectively.
I want to add something on behalf of Paul... I purchased the Invitation in the photo, and his craftsmanship is exceptional. Wing incidences were set correctly, motor alignment, internal gear, all well done!! Would very much recommend his equipment, because of this. Jim
