TOYAN V4 Engine Four Cylinder Four Stroke Methanol RC Engine FS-V400A
Features:
.Small size and large horsepower: Weighing 1150g, need 7.4V or 11.1V battery start, the battery needs to be T-plug, the female head is on the engine end, and the electric rotor is needed. .Fuel:The electric rotor is a general-purpose product, using methanol fuel, this kind of fuel formula is generally: 20% castor oil, nitromethane 5-30%, the rest is methanol; this product does not require high concentration methanol fuel, and can be used at a concentration of 20-25%. .Working Principle: Using methanol as fuel. The process of moving from one end of the cylinder to the other when the piston reciprocates within the cylinder is called a stroke. The four-stroke engine is divided into an intake stroke, a compression stroke, a power stroke, and an exhaust stroke .For Age: 14 years old or older; adapt to 1:10, 1:12, 1, 1:14 remote control car, remote control ship, remote control aircraft, etc., can also be converted into an educational kit for display and education .Note: Do not touch the fan after starting to avoid scratching. Do not touch the cylinder wall to avoid burns Specifications: .Color: As Shown .Material: Plastic + Metal .Engine Dimensions: 113.37 x 97.54 x 100.9mm .Cylinder Diameter: 17mm .Piston Diameter: 16.6mm .Displacement: 3.5cc x 4 .Output Power: 3.2zzps horsepower .Speed: 2500-9600rpm .Needle valve debugging 3.5 laps, idle mixture 3.5 laps, idle speed throttle minimum 2.5mm .Product Dimensions: 15 x 15 x 15cm .Product Weight: 1150g .Package Dimensions: 11.37 x 9.75 x 10.09cm .Package Weight: 2000g .Packing: Box Package Content: .1 x Engine(Without T Plug Battery and Electrical Rotor) |
