3mm 53cc
New price $170 FREE SHIPPING!
It's a strong, smooth running engine really good compression with a great low tone sound. Used in an MSXR I have since sold. It starts 1-2 flips after priming. New DLE ignition. Just rebuilt the carb. Last started 9/3/20 , 2 flips. Comes with the muffler, new DLE ignition, FALCON CF 22x8 (not wood as pictured) Selling because I have recently moved to Warbirds and the side carb doesn't fit my narrow cowls so funding another engine. Fits in a twin or round cowl. Displacement : 53cc Bore : 44mm Stroke : 35mm RPM Range : 1200-7800 RPM Horsepower : 5.5 HP Weight : 1880g all up Fuel/Ratio : Premium Gas mixed 40:1~50:1 Piston Rod : 2 Needle Bearings Crankshaft : 3 Ball Bearing(NSK) Ignition : Auto advance ,voltage 4.8~6 Volt Prop Size : 2 blade 22x8, 22 x 10 ,23x8 ,24x8 Carburetor : Walbro |
