Phoenix Models p-47 (electric retracts)
purchased from Tower Hobbies nib . I took it out of box to inspect for damage all is good re-packed and ready for assembly ,does include electric retracts not pneumatic.
Product Details Key Features Experience Level: Intermediate Plane Type: Scale military Construction: Balsa and light plywood Wing: Bolt-on two-piece Flaps: Slotted to provide function and scale appearance concealing the control horns internally to maintain scale lines Covering: Hangar 9 UltraCote Landing Gear: Heavy duty air retract with CNC machined metal suspension struts, air valve system, air hose, one-way valve Cowl: Factory painted Canopy: Removable for access to battery and radio equipment Cockpit: Detailed with instrument panel, painted pilot bust Top Hatch: Removable for easy battery changes and access to radio gear Motor Mount: Plywood In The Box P-47 Thunderbolt 30-35cc Gas EP ARF Prebuilt and covered Fuselage Wing and Tail sections Landing Gear Hardware Package Instrument Panel Pilot Lens Mirror Gun and Removable Antenna Product Manual Needed to Complete Radio: 8-channel minimum Servos: 9 standard size (2 aileron; 2 flap; 2 elevator; 1 rudder; 1-air valve, 1-throttle (if using gas engine) Receiver Battery: 6.0V 2400-2600mAh NiMH Spinner: Scale type P47 Thunderbolt Building and field equipment For Electric Power; Brushless Motor: Outrunner type, Great Planes ElectriFly RimFire 1.60 recommended Electronic Speed Control: LiPo Battery: 12S 5000 - 6000mAh Propeller: 16x8 - 18x8E For Glow or Gasoline Power; Engine: 30-35cc gasoline Propeller: To match selected engine |
