AeroComp 1660mm Length Full Composite Avanti Sports Jet w/JP E/Retracts/Brake ARF Ver
https://www.austars-model.com/aeroco...on_g21658.html ARF version
https://www.austars-model.com/aeroco...on_g21659.html PNP version https://www.austars-model.com/aeroco...ne_g21660.html PNP Plus versionProduced by AeroFoam team with a full composite version. JP ERetracts/Brake is selected for the project. (3-10 boarding after the order is placed) Avanti Sports Jet has great flying characteristic for entry level or experienced jet pilots to get fun fly before they fly the large jet, very strong and rigid construction which alow to fly fast with 8kg-10kg turbine engines. The team used LT-T95 as the power house with exellent performance. There are four liveries to select. PNP version and PNP Plus version with a turbine are listed Wingspan: 1550mm Length: 1660mm Servo: 7 SERVOS Fuel tank: 1800cc Engine: 6-9kg turbine engine ARF Version: Standard Kit+JP electric retracts/brake+all hardware PNP Version: ARF Version+7 x 35G Metal Servos with wirings+Exhaust Pipe+Power Management Unit (PMU) (You just need your own TX/RX, battery for PMU & RX, and a power engine) PNP Plus Version: PNP Version plus LT-80K Turbine, you just need your own TX/RX & batteries for your RX/PMU and the engine) |
