Interested in a JR transmitter.
I'm interested in purchasing a JR transmitter that works with recievers described below;
PCM-S, NER-649S, 72 MHz, channel 37. pictures are attached. Very good shape and reasonable. thank you all, bill |
I have the 9303 that is 72Mhz that I no longer use. It has the module in it that allows you to select the channel you want to be on. I also have about half a dozen receivers.
HI, HAVE A X388S FOR 40 DOLLARS [email protected] SORRY IF YOU GET DUPLICATES DOSN'T SAY IF YOU RECEIVED MESSAGE. IM IN S. DAYTONA FL.
I have JR 10X with module. You can select FM, SPCM and ZPCM. very clean. $100
NIB 8103. Includes 4 517 servos, battery pack, charger, 649 receiver ch 42, servo arms and power jack. Extra receivers and crystals (ch 15).
$100.00 shipped. [email protected] |
Originally Posted by BRETTMAN
(Post 12680574)
thanks, bill |
Originally Posted by good38
(Post 12680578)
thanks, bill |
Originally Posted by Staggerdwing
(Post 12680583)
$100.00 shipped. [email protected] thanks, bill |
Originally Posted by TheEdge
(Post 12680561)
321-268-0948, and pleas leave me a message as we’ve stopped answering numbers we don’t recognize, and I’m sure you understand. thanks, bill |
I have a like new JR 622 Tsansmitter, charger and receiver.
$50 plus shipping if you are interewsted Thnx, paul |
Originally Posted by pacoflyer
(Post 12680652)
$50 plus shipping if you are interewsted Thnx, paul thanks, bill |
Hi,have a selectable channel module for 20 total 60 bucks and i'll throw in 3 recvrs. P.s. Radio does s pcm and z pcm also
(Post 12680900)
thanks, bill |
I dont have ant 72mhz xmtrs for sale , SUGGESTION, First u need to find out if there any ch 37 crystals out there in either FM or PCM, xmtr & receivers must be on same , SECOND , check w/ spectrum to see if they service JR xmtrs, , check w/ majoor r/c companies stan , (334) 393 1674
Originally Posted by sgrett
(Post 12681491)
Found that radio, thanks to all!!
Originally Posted by brickwoodward
(Post 12680526)
PCM-S, NER-649S, 72 MHz, channel 37. pictures are attached. Very good shape and reasonable. thank you all, bill bill |
