Go Back  RCU Forums > Radios, Batteries, Clubhouse and more > Product Announcements & Manufacturer News
Reload this Page >
3D Foamy's new PRO 3D kit with G-Force wings!
Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news or have a new product announcement you may post it here.
Old 11-18-2004, 12:25 PM
Levi_Jordan
My Feedback: (21)
Levi_Jordan's Avatar
Default 3D Foamy's new PRO 3D kit with G-Force wings!
All foamy's are NOT created equal.....
Ok, sorry about the corny "G-Force" name... but I thought it sounded cool!
This started as a fix to the only complaint I get about the kits....
... " I had to cut the spar slot...."
Well, I don't like complaints, so I scratched my brain and came up with the newest and coolest wing design!
It's the same weight as before, easier to build, flies better, looks better and is stronger than any other flat plate foamy out there!
I am designating this the "Pro 3D" option for the kits...
So what does the new "PRO" version get you????
1) All Depron (not "Ultrafoam") LASER cut parts, all hardware, my "Torqued" motor mount system, and the Build CD with all the videos, plans, and manuals.
2) G-Force wing design: This is the heart of the pro version. It is a 6mm depron core, the spar cutout is laser cut FOR YOU! So are the aileron servo cutouts... Then the beautiful LE is all lightened up with the lightning holes.... To top it off, the control horn slots are all cut, ready for the cool 3D Foamy 3D control horns (included) The Beauty of the deal is the top and bottom LE wing skins. It allows for slower airspeeds on the downlines, totally eliminates high speed "hunting" (not much to start with though) and improves the tracking to the point that you WILL NOT think you are flying a "Flat" wing... The top wing cap covers the servo and lightening cutouts... The bottom wing cap makes it all symetrical... By sanding the LE round, it creates a good seperation point for good clean snaps. The Caps carry back to MAC , then bevel into the 6mm section. This creates a small vortex down the rest of the wing, allowing better aileron control, less wing rock, and a little more "lift" for slower landings. This also helps out with the glide ratio.... It looks awesome too.... the aileron servos and wires are completly hidden in the wing. No more servo leads dangeling in the wind!
3) Direct Drive rudder and elevator linkage. The servos are located as close as possible to the flight surface. It uses a short carbon pushrod for control... The plane flies like a 40%er, and so now the controls are setup the same too!
Here's a shot of the kit contents....
Bottom line is that this is the stiffest, most precise, most accurate flying and building kit to date.
Old 11-18-2004, 01:11 PM
bdavison
Default RE: 3D Foamy's new PRO 3D kit with G-Force wings!
(in the voice of Homer Simpson) drool...mmmmmmmarghhmmmarmmm....AiRpLAnE.........M mmmmArgamm
Nice work.
I WANNA SEE THE KIT FOR THAT F-15 Park Jet.
I watched the video, and dang that thing flys nice. Its the first jet Ive seen that actually looks like it flys like it should. Good low speed, and a rocket when you need it. Ive got a Great Planes gas F-15, and it does NOT like slow speed. I even put a functioning airbrake inbetween the rudders. I like the plane, just wish it flew better. Its a speed demon.
Im dying to see those F-15 plans.......PLEASE put em up.
Old 11-18-2004, 01:37 PM
jmiracle
My Feedback: (9)
let see some assembled pics of this new wing design...and more importantly...some video!!!
Old 11-18-2004, 01:41 PM
Levi_Jordan
My Feedback: (21)
Waiting for the weather to clear to pull out the camera... We got rain and cold right now...
I'm uploading the construction pics now...
Old 11-18-2004, 03:11 PM
tashley
My Feedback: (9)
tashley's Avatar
The thing looks absolutely first rate. If the wing performs as it should, the flying charteristics should be greatly improved over what we've experienced before with flat plate wing designs and I love the idea of moving the tail servos closer to the tail. Levi, the truly great never rest. Can't wait to get my hands on one.
Old 11-18-2004, 03:16 PM
rcflyerrc
When will you have the construction pix up?
Ralph
Old 11-18-2004, 04:58 PM
Levi_Jordan
My Feedback: (21)
Here's some shots of it all finished up....
AUW 13.1 oz (Previous SU was 12.7, but had lighter esc and motor)
Geared MTM400 (35 oz thrust)
Falcon 1100 3s1p
4 BMS-371 serovs
Pheonix 25
APC SF 12x8
Old 11-18-2004, 05:33 PM
tashley
My Feedback: (9)
tashley's Avatar
Spectacular!!! Levi, did you generate those graphics? The plane looks great.
Old 11-19-2004, 12:27 AM
Levi_Jordan
My Feedback: (21)
the Graphics are my home brew... Digital crystal clear on perm. decal sheets... Just put them on the website too! They turned out great! I just got a new machine for making them up....
Old 11-19-2004, 12:30 AM
Levi_Jordan
My Feedback: (21)
I just released my PRO kits that have the cool new G-Force wing...
I thought of dumping the FFF kits because you still have to cut the spar slot...
If I cut all the way through the wing so you can glue the spar in easily, would this be good or bad?
For more info... I use this method on the Park Jet kits... The spar gets cut all the way through, then a strip of 3M Satin (Gift Wrap) tape gets applied to the top and bottom. it paints nicely.
Since looks are not the greatest concern with FFF, would this be a good alternative to cutting the spar slot out???
Here's the F-18 with the Spar cut all the way through...
Old 11-19-2004, 12:17 PM
fun_fly3d
Levi,
This new wing/plane design looks awesome! How soon do you expect to have the Edge 540 in the Pro Version?
Old 11-19-2004, 01:18 PM
Levi_Jordan
My Feedback: (21)
I have the files all done for it... just have to build it and do the manual changes... The Katana is done too...
Old 11-20-2004, 03:19 PM
Woodsy
Yep, go for the spar slot in the FFF kits
Old 11-21-2004, 09:40 PM
Levi_Jordan
My Feedback: (21)
Finished up the Katana, CAP 232, Edge and Extra 300L in the new G-Force wing design... Gotta tell ya, makes the building go so much easier!
Old 11-22-2004, 05:58 AM
Levi_Jordan
My Feedback: (21)
The rest of the kits are now "G-Forced".. so all new orders have the PRO option in Depron now....
I also finished up the manual for the PRO kits... Here's a link if you want to take a closer look at the construction methods.
http://3dfoamy.com/Manuals/SU26_PRO_Manual.pdf
Old 11-22-2004, 08:54 PM
kennyandannie
Good work Levi,
I'll be picking up a couple of your pro kits in a couple of weeks. I have to have something new to fly when I take a break from putting that new 35% fuse together. You know how it goes, work for an hour or so, fly for 20 minutes, back to work for an hour or so. I have a constant supply of LiPo's charged for a quick flight when " I just have to fly".
See ya,
Ken
Old 11-23-2004, 12:08 PM
WhtBronco
WhtBronco's Avatar
Levi I am really impressed with your planes and appreciate the Made in America stuff. I'll be picking up 1 of your bipes around the 1st of the year. I cannot believe your prices. Being at or below the big names, I don't know how you make any money.
BTW, congrats on the new addition to your family. Now you'll have someone to fly with in a few years. My 3.5 and 7 year old daughters are both flying with me now days. We have a great time at the field together.
Old 11-24-2004, 12:53 AM
8KCABrett
8KCABrett's Avatar
Wow, interesting design, looks very nice and clean! I have been thinking of getting an electric 3D'er and this looks like a higher quality than any I have been looking at. Now that I see there is a Raven I know which one I will be starting with, I fly with, and am coached by Wayne in the full size Raven and Extra, and would love to have an RC variant! Do you plan on producing decal sheets for the Raven, or can you for an additional charge?
-Brett
Old 11-24-2004, 01:07 AM
Levi_Jordan
My Feedback: (21)
I'm in the middle of getting the Raven all done for the graphics and such... should be after the weekend sometime. Say Hi to Wayne... we chatted about doing some flying, but with a new house, new kid, and a busy business... I just havn't made it down there yet!
Old 11-24-2004, 10:38 PM
Shortman
My Feedback: (21)
Shortman's Avatar
Looks great Levi, I can't wait to wring some of those planes out.
Old 11-25-2004, 01:07 AM
3D-kid330
This is a really cool wing design! After you sand it, is it completely airfoiled?
Looking foward to flying one,
Brandon
PS-Are you doing the Team 3DF?
Old 12-04-2004, 02:34 AM
8KCABrett
8KCABrett's Avatar
I am adding things to my shoping cart. . . for power I am looking at the AXI 2212/34, but as an electric Newbie I am uncertain about the LiPoly selection? Any advice on what would work best in this case would be great!
-Brett
Old 12-04-2004, 10:20 PM
Looper
My Feedback: (22)
Hi. new wing looks great. I have a Sukhoi that I intend to start in a few weeks..Can I buy the new wing for it? thanks, Looper
Old 12-05-2004, 09:53 PM
William Robison
Hey folks:
This thread is now in the Product announcement forum, discussion and questions aren't allowed here. Not going to prune the thread, but pleasse don't make any more posts.
Thanks.
WLR
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
