Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news or have a new product announcement you may post it here.
New Engine now available
Old 02-28-2007, 09:43 AM
hvac
My Feedback: (7)
Default New Engine now available
The new 3MM Gas motor is now available at www.dawghouserc.com. I have one on my Wildhare Extra 300LX. As soon as the weather breaks I will have more info on how it runs. He also has aluminum spinners and aluminum standoffs. Very nice high quality stuff and great prices. I used his standoffs, 3.5" spinner and the stock 3MM muffler on my Wildhare. My airplane had a DA 50 on it orginally. Had to modify the cowl a little. The mounting hole pattern to mount the motor is different than the DA50 and the carb is side mounted instead of rear mounted. Using a servo for the choke also. Everything looks nice and can't wait to fly it.
Old 02-28-2007, 11:49 AM
rmh
rmh's Avatar
Default RE: New Engine now available
I can't get thru to Scott - -and anyone trying the CONTACT link should note that it is NOT a valid EMail - it is written as c.om not .com
Scott-- please EMail me
Dick
Old 02-28-2007, 01:13 PM
v-snap
My Feedback: (18)
v-snap's Avatar
[email protected] Another mistake by the computer whiz he forgot a c
Old 02-28-2007, 01:26 PM
v-snap
My Feedback: (18)
v-snap's Avatar
Dick I sent you an e-mail
Scott
Old 03-01-2007, 10:31 PM
max-nix
What type of induction valve does the 3MM use? Is it a reed valve?
I like it's looks!
Old 03-02-2007, 08:54 AM
Geistware
My Feedback: (16)
THat is one of the lightest engines I have ever heard of.
Weights - Engine Only - 3.1oz
Old 03-02-2007, 08:56 AM
Geistware
My Feedback: (16)
Also see they have an Indiana address and a Connecticut phone number.
What is up with that?
Old 03-02-2007, 10:02 AM
v-snap
My Feedback: (18)
v-snap's Avatar
You caught me, I live in indiana haven't changed my cell over yet since my daughter lives in Boston...Geistware you really hunt for things. If your a moderator I think you need to act a little more professionally coulda asked that in a pm....But I have noticed it is typical for this site to act in that manner.
Yes it is a 2 petal reed, and the specs should be 31.0 If I remember right. I was advised of this yesterday on the missed decimal point.
This is turning a msc 22X10 out of the box at 6800-7000 Dick hanson threw a 24X8 on it and if I remember right hit 6400 on a new engine I sent him to play with.
Any further question don't hesitate to ask.
Scott
Old 03-02-2007, 12:02 PM
max-nix
Do you have the factory specs., such as xxx ft pounds of torque @ xxxx RPM?
Old 03-02-2007, 12:12 PM
v-snap
My Feedback: (18)
v-snap's Avatar
The engine is rated at 5.5hp. This engine is being imported from china, we are still processing that information. We can plug it into program but find diffrent programs offer diffrent answers. I will try to come up with some suitable numbers for your information over the weekend concerning this. I will gurantee you will not be dissapointed in this engine, it has proven to be quite an easy natured engine with alot of potential.TOC-53
Displacement
53cc
Bore
44mm
Stroke
35mm
RPM Range
1200-7800 RPM
Horsepower
5.5 HP
Weight
1880g all up
Fuel/Ratio
Premium Gas mixed 40:1~50:1
Piston Rod
2 Needle Bearings
Crankshaft
3 Ball Bearings(NSK)
Ignition
Auto advance ,voltage 4.8~6 Volt
Prop Size
2 blade 22x8, 22 x 10 ,23x8
Carburetor
Walbro
Scott
Old 03-05-2007, 02:00 PM
jrjohn
My Feedback: (24)
Dick, did you recieve the 3mm yet, if so, what is your opinion of this engine
John
Old 03-05-2007, 04:05 PM
rc-sport
My Feedback: (12)
rc-sport's Avatar
v snap, I bet you had that engine when you had your Ultimate Pitts. WIth the supplied muffler, how much bark (noise) does that motor have? Looks nice.
Old 03-09-2007, 10:44 AM
v-snap
My Feedback: (18)
v-snap's Avatar
Muffler is quite good and does a normal job of sound control. It is very light so it won't help much with the balanceing of the engine. I will send an engine to Bisson and have a wrap around designed for it in the near future. We do know that the Moki mounting holes are the same as a friend was looking at trying the muffler on his big moki.
Dick has run the engine I will let him comment on what he thought. He may not have found this thread since it was moved.
Scott
Old 03-09-2007, 11:20 AM
rmh
rmh's Avatar
engine is 4 pounds -- not 3 lbs so it is heavier than the lighter 50s but same as 3W essentially
very smooth runner - easy start - no leaks easy restarts -low vibes -all in all very nice engine. good quality!
the muffler sounds quite nice -for in cowl muffler- and does not harm power on the 24x8 - quite a surprise.
I would use it on this engine if I was to use in cowl muffler .
I would take it over any of the piston ported designs in that weight range 50-60 cc - -Having run Zenoah and Fuji in this size /weight --They both had notable vibration at 3000 --this one has none there - just a little bit right at 2200.
Old 03-09-2007, 04:23 PM
riggit1
My Feedback: (24)
Just recieved engine from China, quicker shipping than from in the states. I am planning on putting it on the M12 Python, with a 23x8 prop.
Questions, the prop washer is so tight I can't get it on the shaft, same with the prop. Is the shaft larger than 10mm?
Do I need to use 22x8 for break in like the DA?
What fuel grade and mix are you using? Do you have any suggestions???
Riggit1
Old 03-11-2007, 02:34 AM
PLANE JIM
My Feedback: (109)
who provides warranty service for this new product????????
Old 03-16-2007, 09:32 AM
hvac
My Feedback: (7)
deleted
Old 03-20-2007, 03:57 AM
olstoney
My Feedback: (19)
hvac,
A couple of questions for you and I have sent an e-mail to Scott. You are advising a 2 year warranty and Scott's website advises 1 year, which is correct? I have the new style Wildhare Extra 300 due in here tomorrow. I'm not sure if Wildhare changed the firewall length on the newer Extra as compared to the older. What length standoffs were required for your plane?
Old 03-20-2007, 07:58 AM
hvac
My Feedback: (7)
deleted
Old 03-20-2007, 09:29 AM
olstoney
My Feedback: (19)
Thanks for the info. For myself, I'd rather pay a little more and have the extra years warranty. Of course warranties don't mean anything when you dirtnap the engine .
Old 04-04-2007, 02:43 PM
hvac
My Feedback: (7)
Old 07-11-2007, 07:46 PM
Forgues Research
My Feedback: (7)
Forgues Research's Avatar
ORIGINAL: Geistware
Just a note, you can have different states phone numbers,
I live in Ontario Canada and my phone number is a Las Vegas number using skype, , isn't technology wonderfull???
Roger
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
