Go Back  RCU Forums > Radios, Batteries, Clubhouse and more > Product Announcements & Manufacturer News
Reload this Page >
MT70CC TWIN coming soon. Nothing compare this one !!!
Product Announcements & Manufacturer News If you are a manufacturer or company with relevant news or have a new product announcement you may post it here.
Old 01-17-2010, 09:09 PM
mtenginesusa
Default MT70CC TWIN coming soon. Nothing compare this one !!!
Too many single cylinder engine on the market for 50CC class plane now. we can make long long list for that . DA50/3w55/MVVS50/ZDZ50/DLE55/CRRC50.... .but now. things is change ! MT are bring new engine to this mareket . the MT70 TWIN !!
This is the only twin engine under $500 and can swing 24-8 prop up to 7K with stock muffler ! and engine weight only 3.26lb with plug !!!. people know the advantage of twin engine compare with single . smooth without vibration . and we made it still light weight just like single cylinder engine
Engine weight only 3.26lb with plug!!!!
Specifications:
Displacement: 70cc
Bore: 37.5mm
Stroke: 32mm
Ignition: RCEXL
Carb : Walbro HDA
Engine only weight 3.26lb (with plug)
Prop range: 22X10 - 24X10-26X8
RPM Rang 1200-8500
Cheers
Tomy
MTENGINES CHINA / MTENGINESUSA
ID:	1358566   Click image for larger version
ID:	1358567   Click image for larger version
Old 01-18-2010, 10:28 PM
taildragger21
My Feedback: (197)
taildragger21's Avatar
Default RE: MT70CC TWIN coming soon. Nothing compare this one !!!
Nice !! Great job!! Looks like a perfect 30% engine!
Old 01-19-2010, 03:37 AM
unit53
im waiting for mines to arrive,and from reading my posts im sure our fellow readers allready know,,,,although it may not be very technical,i wil be giving my honest opinion/evaluation
Old 01-19-2010, 08:35 AM
gargajm
What are the dimensions from spark plug cap to spark plug cap. I am concernded about getting this engine in a cowl without butchering the cowl up and have the spark plug caps sticking out. It would have been nice if they could have slanted the spark plugs back to help the fitting situtation.
What say you Tommy????
Old 01-19-2010, 09:33 AM
tomyrcmodels
tomyrcmodels's Avatar
Hi
The width of this engine are CAP TO CAP 270mm. (straigth plug) and 260mm 30 degree angle plug . the cylinder we made are prepare for single 35CC engine that use straigth plug and for the twin . both version are available .
Cheers
Tomy
ID:	1359492   Click image for larger version
Old 01-19-2010, 09:50 AM
gargajm
ORIGINAL: tomyrcmodels
Hi
Cheers
Tomy
Thanks Tomy!! So, just to make sure I am reading you right. You are saying I can order the twin with cylinders for the angled plugs????
Old 01-19-2010, 09:58 AM
tomyrcmodels
I will let you know when the angle spark version ready . give me email and I let you know it's soon
Tomy
Old 01-25-2010, 05:56 PM
seagull extra
My Feedback: (12)
Are the angled plugs going to point up or down?
Old 01-26-2010, 09:11 AM
seagull extra
My Feedback: (12)
Guess I didn't look at your drawing close enough. I can see they are going to point down. Thats good.
Old 02-04-2010, 09:37 PM
mtenginesusa
MT 70 are going to ship to USA this week, so MTENGINESUSA are accept order for this engine . also the MT35 good luck
Tomy
Old 02-05-2010, 10:37 AM
tomyrcmodels
FIRST ECHELON
ID:	1372230   Click image for larger version
ID:	1372231   Click image for larger version
Old 02-09-2010, 02:24 AM
unit53
When i first heard tommy does listen to his customers ,i didnt have a point of refrence,not heres a point in fact,,after thinking about it ,ill only have to make a slight clearance on the left side looking forward,,because of thrustline offset,,,im anticipating theese engines will sell like hotcakes,,imagine,if it had have been made by our high priced ,suppliers,easily 750.00 or more,,i think 3/w made a 70 twin for about 775,00.. this has got to be what all modellers in this class want power and good proce ,greatly reduced vibration,and long lasting airframes,,ive seen way too many 50 cc class planes crash due to component failure,most likely due to overworking an airframe ,the only way to smooth out an engine is balance it as best as possible,the boxer twin cancells out most of the issues there.of course theres explosions going on there so its giong to pulse but not try to self destruct like a single is more prone to do,i once had a 50 cc plane idling in my yard,came back 10 minutes later to find the wheels off and severe servo gear slop ,from the piston slap,,,,ithink this type of engine is going to make our flying much more fun ,instead of re gluing and replacing worn beat up parts,less maintenence more flying.
Old 02-09-2010, 02:45 AM
unit53
ORIGINAL: seagull extra
Tell you this much,,,whether up down or back,,its going to make it much more sellable,when people see me flying with a 70 cc twin and its well under 500.00 they will want one for sure
Old 02-12-2010, 08:14 PM
unit53
OK folks,,its HERE ,i thought id have it mounted within two hours,,nott,,,, ill get back and let the readers know what i did and what came in the box besides a verrry nice looking  little 70 cc twin,,ill try to take some pics as well..the run video should be on you tube by tomorrow..
Old 02-13-2010, 07:25 PM
unit53
 ok  you all go to youtube click on channels,,not videos  then type in norm53 ,,very impressive engine you can see and hear for yourself,, im only guessing but at 3200 feet asl,where i ,live ,,my calibrated elbow was feeling over 35 pounds of thrust   ive got a 55 pound warbird  thats flying with a 39 pound thrust engine ,,i wonder what my 17.5 pound yak will do with 2 to 1 thrust????[X(]
Old 02-13-2010, 09:22 PM
tothemax
When I enter norm 53 I get this: Sneah Beerm Kom Norm #53 What am I doing wrong?
Old 02-13-2010, 10:34 PM
gargajm
ORIGINAL: tothemax
Me too!!! I can't find it>>>
Old 02-14-2010, 01:48 AM
unit53
go to you tube instead of videos,,,click on channels then type in norm53 or onder videos type in mt70 cc twin but you have to use the same spacing ,and once you get there you can click on my name
Old 02-14-2010, 02:01 AM
unit53
ORIGINAL: unit53
go to you tube instead of videos,,,click on channels then type in norm53 or onder videos type in mt 70cc twin,and once you get there you can click on my name
one day ill learn how to post links,,or someone will show me,,,but spell it exactly like this,,, mt70cc twinfirst run..
Old 02-14-2010, 02:38 AM
tomyrcmodels
[link=http://v.youku.com/v_show/id_XMTUyMTQ5Njcy.html]MT70 FIRST RUN orig from UNIT53[/link]
Old 02-14-2010, 02:46 PM
unit53
and it runs like a clock but not any clockmaybe a rolex ,theres pics in my gallery here in rcu,,and follow the link to youtube or just go to channels and type in norm53 ,i would put it in the air today,,but im on painkillers for a molar that got ripped out yesterday,, its only had a quart of fuel so far,and it had run flawlessly so far,, at this point my overall impression is WEHAVEAWINNERHERE ,stay tuned for further results and info.
Old 02-28-2010, 01:29 AM
mtenginesusa
few new photo of MT70
ID:	1388328   Click image for larger version
ID:	1388329   Click image for larger version
Old 03-10-2010, 10:28 PM
PlaneKrazee
My Feedback: (14)
PlaneKrazee's Avatar
Hello,
When will the slant plug version be available? I think it will just fit inside my Aeroworks Extra 300 cowl.
Regards,
Brian
Old 03-11-2010, 10:43 AM
PlaneKrazee
My Feedback: (14)
Placed order for the slant plug version. I hope to have it in my plane before the end of the month! Thanks Tomy and Jack!
Old 03-24-2010, 06:40 PM
hairy46
Tomy, Will you be making an engine for around the 60 sized airplane? I have so many of that size and tired of paying for the high dollar glow fuel! Thanks Bob
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
