MT-57CN
1 Attachment(s)
MT-57CN
Engine type: 2-Stroke gasoline engine Displacement (cylinder volume): 57cc Bore×Stroke: 44mm×38mm Spark plug: NGK BPMR6 Bearing: SKF 6003,6002 Carburetor: Walbro HDA Max power: 6.2hp/7400rpm Practical running speed: 1500-8000rpm Net Weight: 1495g with plug only Ignition system: CDI battery ignition (battery voltage: 4.8v—6v) Grease oil ratio: 25-30:1 used during the break-in (the initial 2 working hours): 35-40:1 used after the break-in. Screw propeller dimension: 22*10, 22*12, 23*8 ,23*10,24*8,24*10,24*12 TOMYRCMODELSUSA WEBSITE : HTTP://TOMYRCMODELS.COM photo link: http://picasaweb.google.com/tomyrcmodels/MT57CN testing video link: http://www.youtube.com/watch?v=PnKM5IcsLE4 |
