Go Back  RCU Forums > RC Airplanes > Profile and Fun Flying Planes
Reload this Page >
AK Models Simple Flier
Profile and Fun Flying Planes If you're a profile fan or into fun flyers than this is the forum to discuss those topics.
Old 10-11-2015, 06:46 PM
cckc135r
Last in 2006....I'm ready to start covering this hotrod and hope some folks are still flying them. The build has been great with several of my own deviations from the plans.....still looking to see if anyone has any video of it flying and if the prescribed CG is right. Any help would be greatly appreciated.
UAVC (03-26-2022)
Old 10-12-2015, 06:21 PM
thebluemax
My Feedback: (151)
thebluemax's Avatar
I just finished covering mine a few weeks ago. The hardest part to cover is the trailing edges of the ailerons and flaps. If I had to do it over again I would have somehow put a strip of balsa as trailing edge sheeting to give the covering a nice flat surface to grab on to. The rest wasn't too bad.
No video or maiden yet. Not sure when that will be. You might want to balance it before covering it, in case you need to add any weight. It would be easier to do before covering. Especially to lateral balance it. I ended up adding a lot of weight but it was my own fault because of the way I had to install the battery pack and radio gear. I also had to add a servo for the nose gear as it kept turning the opposite way from the rudder no matter how I routed the cable. My battery and nose gear servo would not fit in the fuel compartment unless I put a real small tank in there. I have an Enya 45CX in the nose so that was not an option. Pictures of mine while waiting for a new spinner.
Good luck with covering.
ID:	2125106   Click image for larger version
ID:	2125107   Click image for larger version
ID:	2125108   Click image for larger version
UAVC (03-26-2022)
Old 10-13-2015, 12:53 AM
cckc135r
Looks good, did you follow the instruction supplied CG point? I've heard some folks say it's too far forward or seems that way at least. I'm using the V-tail mixer so I don't have to add an additional servo for steering and I have also put aileron servos in each wing. The throttle servo is a micro and I'm powering flaps with 2 Hitec HS-65HB's.
Currently working on filling the dents and dings then hopefully cover soon.
UAVC (03-26-2022)
Old 10-13-2015, 05:50 AM
thebluemax
My Feedback: (151)
thebluemax's Avatar
I used the supplied cg point to balance. I think the way the wing is swept back and that it is a long way back to that big tail from the cg point that it may look too far forward but we shall see. My battery is mounted in the wing which is behind the cg and is why I needed the weight up front. I used the v-tail mix in my radio but I still needed the extra servo. I have 8 servos in the plane, 2-flaps, 2-ailerons, 1-throttle, 1-rudder, 1-elevator and the nose gear. They are all standard servos except for the one for the nose gear.
ID:	2125131   Click image for larger version
ID:	2125132   Click image for larger version
UAVC (03-26-2022)
Old 10-20-2015, 11:05 PM
cckc135r
The way I built my ailerons and flaps was one of the things I did differently. They are built similar to the wings in that they have ribs and have been completely sheeted for strength. I will have to get a picture and post it so you can see it. They add a few grams to the overall weight but I feel they are much stronger.
Again, I will get a picture and post them so you can see what I did. Sorry for the delays in my response
Old 01-05-2016, 08:51 AM
  #31
MsgtRob
Does anyone have the manual for this plane? Any news of a re-release on the kit? I'm kit bashing one with a set of long EZ wings .....should be interesting....
UAVC (03-26-2022)
Old 01-05-2016, 08:57 AM
  #32
thebluemax
My Feedback: (151)
thebluemax's Avatar
Here is a copy of the manual. As far as I know there is nothing new on the Simple Flier. But then again I have not really been looking. Good luck with your bashing.
File Type: pdf
UAVC (03-26-2022)
Old 01-05-2016, 09:29 AM
  #33
MsgtRob
Default SF Bahed
Thanks for the Manual !
Some progress...This wing configuration opens the fuselage and provides more space than needed for electronics...I'll use an Eflite Electric 60 size motor and a few other parts from the EZ (Landing gear and gear mount box)
ID:	2139839   Click image for larger version
Old 01-05-2016, 09:30 AM
  #34
MsgtRob
Default SF Bashed
Thanks!
Old 01-05-2016, 09:43 AM
  #35
thebluemax
My Feedback: (151)
thebluemax's Avatar
Your welcome Sarge.... Build looks good.
Old 03-26-2022, 07:47 AM
  #36
UAVC
UAVC's Avatar
Default construction plan
hello.
Do you have the construction plan for this plane?
I need it...
Old 03-26-2022, 07:57 AM
  #37
UAVC
UAVC's Avatar
Does anyone have the construction plan for this plane? help me...
I want to build this plane.
I know it has a beautiful flight, I like it very much.
Old 03-26-2022, 07:06 PM
  #38
thebluemax
My Feedback: (151)
thebluemax's Avatar
Hello,
I have to look but I don't think so.
UAVC (03-26-2022)
Old 03-26-2022, 09:42 PM
  #39
UAVC
UAVC's Avatar
Hello,i downloaded the manual, I'm just waiting for the aircraft construction plan.
please. do your best.thanksssssssssssss
Old 03-28-2022, 05:44 AM
  #40
thebluemax
My Feedback: (151)
thebluemax's Avatar
I looked and unfortunately, I do not have them. I must have included them in the other kit that I sold years ago. Sorry. Good luck finding a set.
Old 03-29-2022, 05:12 AM
  #41
UAVC
UAVC's Avatar
I was hoping to find it, I should search more.
Thank you for your time.
