Go Back  RCU Forums > RC Airplanes > Profile and Fun Flying Planes
 burrito missing parts../ build questions >
Profile and Fun Flying Planes If you're a profile fan or into fun flyers than this is the forum to discuss those topics.
Old 08-16-2004, 07:10 AM
My Feedback: (45)
PaulSwany's Avatar
Default RE: burrito missing parts..
I wouldn't round those control surfaces... Just knock of the edge a little and cover it..
Old 08-16-2004, 01:31 PM
hey thanks for your help again paul.
ok so i have built the wing with all the ribs..
then i have the 2 solid ones left over..
do you glue those on the edges or what
to make the edges of the wing stronger..aka wing tip..
also what do you do with the extra antenna wire once its been routed through the antenna tube installed in the wing ?
thanks
Felix
Old 08-16-2004, 04:10 PM
wild fred's Avatar
yeah, the solid slightly oversize ones are the tip plates. I usually make a loop in the receiver compartment and let a couple inches of antenna dangle out of the tube, never had problems with that.
Old 08-16-2004, 08:00 PM
does the antenna stay 100% inside the wing though ?
-Felix
Old 08-16-2004, 08:02 PM
My Feedback: (45)
PaulSwany's Avatar
Default RE: burrito missing parts../ build questions
All except for a couple of inches hanging out of the end of the wing.
Old 08-16-2004, 08:58 PM
  #31
would it be bad to ca the antenna or somehow stick it inside the wing? you know zig zag it so its fully enclosed??
also
do you put cap strips on the ribs where the servo rails go ?
-thanks
Felix
Old 08-16-2004, 09:08 PM
  #32
My Feedback: (45)
PaulSwany's Avatar
I've seen fully enclosed antenna's... Using a tube inside the wing. I've just never opted to go that route.
Cap strips on the ribs where the servo rails go? The area on top of the servo rails is sheeted. I'm not sure I understand what you mean.... Can you post pictures?
Old 08-16-2004, 09:21 PM
  #33
nvm that was a stupid question i now realize that it will be sheeted...
i almost have the wing done
this thing should be loads of fun..
alright back to building
-Felix
Old 08-16-2004, 10:47 PM
  #34
a few more questions..
ok besides elevator and rudder and ailerons what should i cover first..
when to cover motor mount?
where is the CG on this thing ?
thats all for now
thanks
Felix
Old 08-17-2004, 09:03 AM
  #35
Burrito Bandito's Avatar
ORIGINAL: Felix21685
thats all for now
thanks
Felix
Felix,
Just my $.02, but I like to cover the bottom of everything first. That way, the overlaps from the top are uniform according to the trim scheme on the top. Don't forget to leave enough wood to glue to on the bottom of the top fuselage half and the top of the bottom fuselage half.
When covering the motor mount, I like to take the covering almost 3/4 of the way back on the sides. When the mount has been covered, I dry-fit it into the wing and make sure it is fully seated. Then take a fine point sharpie and trace the root rib on each side of the motor mount. Remove the assembly and cut and remove the covering along the INSIDE of the line. Now you have bare wood in the appropriate places for glueing when you install the motor mount.
As for CG, I start right on the main spar for the Burrito and adjust as necessary. That is a good conservative setting and should be pretty comfortable.
Got any Pics yet?
Old 08-17-2004, 12:58 PM
  #36
no i dont have the digital with me that i used earlier for the individual pieces..
i will get some pics up here when its covered though for sure..
-Felix
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
