Go Back  RCU Forums > RC Airplanes > Profile and Fun Flying Planes
 help requested anyone who owns burrito >
Profile and Fun Flying Planes If you're a profile fan or into fun flyers than this is the forum to discuss those topics.
Old 08-18-2004, 06:46 PM
Default help requested anyone who owns burrito
hey guys
i was wondering you wired your antenna wire to keep it all inside the wing.
please if you can show me some pictures.
thanks
Felix
Old 08-18-2004, 06:55 PM
Default RE: help requested anyone who owns burrito
That´s an easy one. Simply put an inner nyrod trough the ribs from the receiver area to the wing tip and put the antena in it.
Dont have pictures but is a simple task. to make the holes for the nyrod I use a sharpened brass tube rolled between my fingers.
Hope this helps.
Old 08-18-2004, 08:10 PM
matchlessaero's Avatar
Bolio summed it up just right....
Old 08-18-2004, 09:08 PM
Tanks Match, but I´m only trying to pass some of the wisdom gained from all of you Brothers.
Old 08-18-2004, 09:41 PM
but thats not long enough for the entire antenna.
Do you just run it back towards the center of the aircraft in another tube ?
would this be bad?
-Felix
Old 08-18-2004, 09:52 PM
Let it hang out the tip of the wing
Old 08-18-2004, 11:14 PM
im trying to keep it all inside so it wont get ripped out..
and i think it would look better
should i carefully zig zag it out to the wingtip ?
-Felix
Old 08-19-2004, 01:05 AM
PAR
PAR's Avatar
A trick I've used on my combat planes is to wrap the excess antenna length around a piece of balsa 1x2x1/8 near the receiver. The key is to not let it overlap. Flying close in the reduction in range has been minimal. Looks like a base loaded antenna when your done. Got this tip from a guy who flys pylon.
Old 08-19-2004, 06:57 AM
ORIGINAL: novabill
Ditto.......that is how mine is......run out the end and let it hang
rcam
Old 08-19-2004, 08:18 AM
My Feedback: (9)
ORIGINAL: Felix21685
-Felix
It wont, I have never had a problem letting the extra hang out......... uuuhmmmm DONT go there
Old 08-19-2004, 01:21 PM
SWICK's Avatar
all Ive ever done is poke two holes at end of wing about 3 inches apart run it out one hole and into another. The wire that is showing place tape over it to keep it from coming out.
Old 08-21-2004, 08:56 AM
Clear tape it to the bottom of the wing. Go slow, and it will look fine. Otherwise, small patches of matching covering material can "tape" it down too.
Just don't do any of this if your covering is metallic at all. Metallic covering can really screw with a receiver, and if you have it, the antenna should be well clear of it.
My $0.02
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
