Seagull Harrier 3D .90 arf
Just saw it on the back of the new Model Aviation, any news on it yet? Also when there is a motor size range (say .61 to 1.00 2-stroke) is there a preference to lean to the larger or smaller end of recommended range?
My Feedback: (14)
http://www.rcuniverse.com/forum/m_20...tm.htm#2021476
http://www.rcuniverse.com/forum/m_18...tm.htm#1833186
http://www.rcuniverse.com/forum/m_20...tm.htm#2032884
There is a good bit on discussion about the Harrier in the 3D forum. Above are links to three threads that might have the information you seek.
Eric
Eric
Chefia (07-20-2020)
Chefia (07-20-2020)
My Feedback: (21)
Mine came out just a tad over 8 pounds w/satio 1.00, on 15% fuel and a 15x4w apc pullout of a hover is marginal but doing anything else is fine. I have jumped up to 30 % heli fuel and the 16x4w apc and pullout is better , steady but not rocket ship. mine balanced just right with no additional weight with the 1.00. with a 1.20 you will need to mount your battery toward the rear of the fuse. Throw away the control rods and the control horns that come with the kit. way to flimsy. Other than that, the kit is very well built, much better than the orginal seagull razzel. Surprise-- this plane really will harrier! 20 degrees of up spoilerone and 45 degrees of elevator and you can drive it all over the field in a harrier. Hovers pretty nice too. I haven't been able to get mine to flatten into a true flat spin yet but can get it to knife edge spin. Knife edges ok but has some coupling issues--especially w/ aileron-that you need to mix out. does very smooth waterfalls but needs down spoilerone to keep it from just being a tight outside loop.
zonk
pics of mine:
zonk
pics of mine:
Chefia (07-20-2020)
Hi guys
I have one and now I start to build. But I planing install an gas engine and fly 3D maneuvers. What do you think A NGH17CC or DLE20cc? The dle I think is a little bigger for the plane. And the NGH I think doesn't have enough power. What you think. One of those or another option? Thanks
