Go Back  RCU Forums > RC Airplanes > Profile and Fun Flying Planes
 OMP Hybrid "My Build" >
Profile and Fun Flying Planes If you're a profile fan or into fun flyers than this is the forum to discuss those topics.
Old 03-13-2005, 11:54 PM
  #301
My Feedback: (28)
Default RE: OMP Hybrid "My Build"
Salmon on your latest plane I see from the bottom view of the plane the opening is more up by the cylinder of the engine. Does this provide better cooling of the Engine or access to the motor? I am in the process of mounting my motor and can't wait to fly it also did you mount your ignition,battery and switch in the cowl?
Old 03-14-2005, 07:39 AM
  #302
My Feedback: (28)
What thrust angles are you guys flying with?
Old 03-14-2005, 08:33 AM
  #303
AFSalmon's Avatar
The engine cooling ducting should be similar to that of any cowled gas plane. That means you want about double the exit area as the intake area. Keep in mind the intake area is not the entire square cowl opening as the spinner blocks much of that area. I like the exit area below and behind the engine so that the air flow over the cylinder, down, and out. Also if you run a pipe then you'll need some air flowing over the pipe and out the back end of the pipe.
The ignition, battery, and switch are all mounted in the engine box area inside the fuselage all the way up behind the firewall. Keep this stuff as far from the radio gear as you can. Use a nylon pushrod for the throttle.
I use zero up/down thrust and 2 degrees of right thrust.
Old 03-22-2005, 09:00 PM
  #304
I was looking for a profile plane after i seen one at a fun fly last summer after seeing OMP'S Hybrid on there web site I had to have it. I found the thread and read all there was to read and build my plane. Now I need to get and engine and have been looking at the First Place Engine but think that I should get the 4.2 to have the extra power.
Old 03-28-2005, 08:32 AM
  #305
AFSalmon's Avatar
4.2 should be ok as I've seen the G62 and even a 3W75 up in the nose.
Old 04-05-2005, 09:45 PM
  #306
My Feedback: (28)
AF Salmon i need the decals that are on your plane can you help?
Old 05-13-2005, 05:42 PM
  #307
My Feedback: (67)
Here is my finished plane. Special thanks to B&E graphics as they did an awsome job, and are darn cheap too. Brison 4.2 for power. Haven't flown it yet but will soon.
ID:	270968   Click image for larger version
Old 05-13-2005, 05:48 PM
  #308
My Feedback: (67)
A close up of the graphics.
ID:	270977   Click image for larger version
ID:	270978   Click image for larger version
Old 05-13-2005, 06:51 PM
  #309
My Feedback: (10)
Zippi's Avatar
Cool looking plane dude.
Old 05-13-2005, 08:59 PM
  #310
My Feedback: (21)
Good stuff Bryan ... lookikng forward to your maiden.
If you don't like it I know a guy about my height who will take it from you!
Old 05-15-2005, 07:33 AM
  #311
My Feedback: (21)
mrbigg's Avatar
looks cool. hey, how's the vibration on the Brison?
Old 05-16-2005, 08:00 AM
  #312
My Feedback: (19)
SMALLFLY-'s Avatar
Dang the covering sure looks good on that plane I was holding it while he was running it up and I could feel no vibration problems at all
Old 05-16-2005, 01:28 PM
  #313
AFSalmon's Avatar
Wow Bryan, those graphics really are dang impressive! You might want to offer that package to other Hybrid builders! The Brison 4.2 is about 68cc or so isn't it? That's going to be a powerhouse I'm sure. How did you decide to run the exhaust setup?
Old 05-16-2005, 09:02 PM
  #314
My Feedback: (42)
What's the weight?
What did you use for a muffler?
Old 05-16-2005, 10:54 PM
  #315
My Feedback: (67)
I'll post a pic of the nose with the muffler. The weight is about 18.5 pounds on digital fish scales that have always been pretty accurate.
Anybody can buy those decals, They just need to contact B&E graphics. I can get you in touch with them if someone wanted. I also have a 40 size omp yak all decked out with their stuff and it too has OMP all over it. It's to the arf stage as I haven't finished it but can post a pic if you all would like to see it too.
Thanks for the good comments guys. I hope to really get to wring her out sometime soon.
Old 05-17-2005, 02:21 AM
  #316
Spacey's Avatar
Capthis that thing looks really awesome! Good luck with the maiden flight! Hope all goes well! Oh and we always like seeing pictures of profiles so post them Yak pics!
Old 05-17-2005, 06:50 AM
  #317
My Feedback: (67)
I did get to maiden the thing a Sunday. It flew great although it was very windy. Flies like a great big trainer. Harriers are good. Didn't try inverted yet but will. TR's way to easily. I think it flies about like a giant foamie! In a good way. Veyr stable easy to fly airplane. Lands slower than most gliders! If I get a chance to fly it agin with little wind maybe I can get some in flight pics. But I will sya this I do like the plane so far. the 4.2 is a perfect match for power.
Old 05-17-2005, 09:04 AM
  #318
My Feedback: (10)
Zippi's Avatar
I was there with capthis and SMALLFLY for the maiden this past Sunday. This thing is a hog, one massive piece of lumber and I might add one beautiful plane. All the control surfaces are hugh and maxed out as I suspected. The graphics are awesome and the Brison 4.2 fits like a glove on the business end. It was very windy on Sunday but with a few minor adjustments the Hybrid took to the air as if it were a calm day. Cappy is right, it looked like it took off by it's self and landed very slow like a trainer. I'm not into big planes but if I was, this would be the ticket. Nice job dude
Old 05-17-2005, 09:45 AM
  #319
My Feedback: (67)
ORIGINAL: Zippi
Thanks, next time it is out and it's not so windy your going to fly it. That way we can get you hooked on big planes too. [8D]
Old 05-17-2005, 10:33 AM
  #320
My Feedback: (10)
Zippi's Avatar
Old 05-18-2005, 08:00 AM
  #321
AFSalmon's Avatar
Hey be sure to have that beast at the Pro Bro event in Evansville! I still miss mine a lot and have to start building one as soon as I get time??????? Now 18.5 lbs seems a bit heavier than I'd expect. How much extra weight do you think the 4.2/muffler combo adds over a DA50 with pipe setup? My flamejob Hybrid I had last year was 16.25 lbs with that setup.
Old 05-20-2005, 06:19 AM
  #322
Hello,
Can anyone please tell me the diameter of the wing tube for this plane.
Regards,
Zdenko.
Old 05-20-2005, 07:07 AM
  #323
AFSalmon's Avatar
wing tube dia is 1.25"
Old 05-20-2005, 05:03 PM
  #324
Mike, I spoke with you at the Toledo Hobby Show. I finally got my Hybrid together. Haven't flown it yet (waiting for batteries) which should be in by next weekend. I have the 4-2 First Place Engine in it. You were interested in knowing how it flys with that engine. I will keep you posted. Here are a few pictures of the completed plane.
Luke
Old 05-20-2005, 05:16 PM
  #325
My Feedback: (21)
Anyway to see larger images of it? I can tell it looks good ... but I'd like to see it large!
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
