Any Diamond dusters out there? Need a tip
My Feedback: (12)
More pitch or RPM...
Bout the only way..you might try one of the APC pylon props like the 8.8X8.75...they have narrow blades and ought to let your engine still rev good and give a little more speed. APC also makes 8X8, 8x9, 8X10, props...an 8" diameter will fly a Dust, just a little trickier to launch.
dust
i have an s.t 51 on mine with the same pipe and usually a graupner 9.5 x 5 prop and was clocked at 147 at two thirds throttle! also am running 10% byrons. only problem is it is so fast that if i snap it into a turn or vertical it will literally disintegrate! i am now on my second as that happened to the first.---henry
