Go Back  RCU Forums > RC Airplanes > Profile and Fun Flying Planes
It does exist:  The Hovering Cobra >
Profile and Fun Flying Planes If you're a profile fan or into fun flyers than this is the forum to discuss those topics.
Old 03-19-2003, 03:37 AM
Default It does exist: The Hovering Cobra
Nice Job Andy
You build very fast...wish I could...Gator
Old 03-19-2003, 01:10 PM
wagas's Avatar
Default Thanks GATOR
The secret is to wake up at 4:30 AM when the wife and kids are a sleeping to work on things.
Old 03-19-2003, 03:01 PM
My Feedback: (20)
Default Coooooooool!!!!!!!!!!!!
wagas,
That transparent green looks good on your cobra! What engine are you using?
Old 03-19-2003, 03:39 PM
wagas's Avatar
I'm using a TT Pro 46 w/APC 11 x 4 prop. CG is at 7 1/4 from trailing edge. For now and mine came out a tad tail heavy. I even built the tail with less sticks than the plans show. Futuba 148's all around for servos.
Thanks!
Old 03-19-2003, 03:56 PM
My Feedback: (20)
Let us know how she flies.
Old 03-24-2003, 01:17 PM
  #31
wagas's Avatar
Well She flew this weekend.
I have to say it's a blast to fly. Not as quick as a regular fun fly but still a blast. I removed all the nose weight I had after the 1st flight cause it's so stable. I started with a CG at around 7 3/4 inches from trailing edge. I would say I'm at about 7 inches now.
I don't like the pull pull set up I'm using (spiderwire fishing line) but it does the job.
Of course the only thing I'm doing with this airplane is hovering, which it does quite well. By the 4th flight I was hand launching this into a hover, a little over half throttle as I hold it vertical and let go. (TT pro 46 w/ APC 11 x 4 Prop)
Very stable and for a 40 size it torque rolls rather well. This is the first airplane I can actually torque roll with out aileron input. Knife edge all day if you want verly little to no coupling required, Snaps are very sluggish, stalls are just nose drops. I was kind of suprised the the ailerons are not as response (quick) as I would like them to be in on high rates, I need to crank more throw into them.
I still would like to build another one and put regular landing gear on with a stronger fuse. I have to add triangle stock to the fuse/wing area as it broke free after 2nd landing. (thank goodness for on hand super glue)
Old 03-24-2003, 09:34 PM
  #32
Hey guy's if your not care full at night this will happen to you if you lose sight of it with glow sticks on!!!
http://www.rcuniverse.com/attachment...&postid=789299
Later,
Kyle
Old 03-25-2003, 12:26 AM
  #33
YNOT's Avatar
You PUNK!!!
Can't believe you did me that way.
That plane had a great life. Hundreds and hundreds of flights, may have hit a thousand, not too sure.
It was pulled from retirement just for the Houston Pro Bro, got a new motor and flew with all the glory that the Cobra deserved. In fact, you failed to mention the hovering and 3D show it did, at night, with no lights. Someone had to get a pic of that.
It went out with glory. I feel honored just to have owned one.
Oh yea, I have a new kit...........it will live again.
Old 03-25-2003, 12:28 PM
  #34
wagas's Avatar
Hey that looks rebuildable. I can't see the rest of the wing but it looks like it's not that bad. Just cut the fuse out from around the wing and build another one.....
Old 03-27-2003, 06:36 PM
  #35
Ya thats the thing the Cobra had a very good life and it was time for the cobra to leave. But Ynot does have a new hovering cobra in the box. This cobra had one last good flight on the last day that it lived. It did fly in the dark for the last time!!! With out any glow sticks on it!! After dark is about the best time to fly these types of airplanes!!! Cause there is no wind and the skill that it takes to keep it in close so you can see it. Me and tony have had very good flights after dark and many mid-airs!!! Although not with the cobra!! Flying after dark is fun and exciting with out any lights!!! I can tell you one thing for sure that there will be another cobra born within a few weeks!!!
Later,
Kyle
Oh can't wait till we get three cobras in action to get down and dirty after dark!!!!!!!!!!!
Old 04-16-2003, 03:01 PM
  #36
My Feedback: (20)
Default Cobra Build...1st night
Started building my first "cloned" Hovering Cobra last night. I ordered a lot of balsa stock so I could weigh each individual piece for optimum weight reduction. It is amazing the difference in balsa weights. Some cuts of the same stock varied as much as 4-5 grams! I completed the horizontal stab and the rudder. Built stock with the exception of going with 1/8" x 1/4" stock for the diagonal braces instead of the 1/4" square stock on the plans. This is suggested in the manual, so I figured every little bit of weight savings in that long tail would be good. Weight of these components is 1.25 ozs ! Edges have not even been beveled or rounded yet! I am hoping to achieve a flying weight of 4lbs with standard radio gear and an OS .46fx. I will try to get the fuselage done tonight. That's only 8 pieces to glue together, shouldn't be a problem.
Old 04-16-2003, 03:02 PM
  #37
My Feedback: (20)
Default 1st night continued....
Here is the rudder.
Old 04-16-2003, 06:41 PM
  #38
wagas's Avatar
Default saving weight
On mine I omitted the cross bracing (the "X" format that the plans show for building the horz stab) I thought it was overkill and alot more work than I wanted to do. If you look at my PIC #3 you can see what I'm talking about.
I've been flying mine and think it's a hoot to fly but SO fragile. It's funny to watch this thing when doing violent manuevers. The tail looks like it's going to twist off. Also, when flying in the wind for some reason my tail (entire back of fuse) starts wagging back and forth like a dogs tail. I get a lot of laughs when that happens. It's still completely controlable but funny looking. Oh, this is when it's at almost idle pointing into the wind. It stops as soon as i throttle up. Don't ask me I don't know why.
GREAT Hoverer, you can do it as long as you want. I think I will end up getting rid of it though as I'm starting to get bored with it. just have to see. The wing and tail are great and i would love to build a stronger Fuse that can be removed and mount a .61 on it as this is a bigger than normal profile (it's hard to fit in the car.) Plus I would do away with the single wheel. I would just use gear like the menace has. I get tired of hand launching this thing.
I can hover w/TT pro 46 and 11 x 4 prop at about 1/2 throttle with instant pull out.
Old 04-16-2003, 07:26 PM
  #39
My Feedback: (20)
Default Flying...
wagas,
What about knife edge flying?
Will it do waterfalls?
Old 04-17-2003, 12:34 AM
  #40
Ya these things will do a real nice knife edge hover in good wind!!
Hey try it!!!
Later,
Kyle
Old 04-17-2003, 12:38 AM
  #41
wagas's Avatar
Yes Knife edge forever with just a tad bit of coupling. If I could get more throw out of my rudder I would say it would do knife edge loops with ease. (I'm using standard servo control horn and just can't get that much throw on the pull pull set up that I want.) Water Falls, Hhmm If I'm understanding what a water fall is I would say they look more like really tight loops than a flip. I can get mine to flip once but after that it just does a loop before I can get another flip out of it.
Old 04-17-2003, 12:40 AM
  #42
The thing to try with this airplane is inverted flat spin, brush the tail in high grass, pop up into a hover, tail touch, then do an climbing inverted flat spin out of it!!
Later,
Kyle
Old 04-20-2003, 05:57 AM
  #43
I would love a set of plans for this, if anyones willing, i think scaled down it would make a great parkflyer electric
Any takers?
Dylan
Old 04-22-2003, 01:31 PM
  #44
My Feedback: (20)
Default Hovering Cobra Clone Construction
Easter festivities kept me from working on the Cobra until last night. The Fuselage is completed (except for rounding the edges). I was surprised at how well the parts fit! I used 30 minute epoxy to laminate the fuselage parts together. The fuse is stronger than I expected.
I wonder if carbon fiber cloth can be laser cut? Then the fuse core could be strengthened by sandwiching the carbon cloth between the balsa core and the ply skins.
This thing is going to be lite! Tonight I begin the wing.
Old 04-22-2003, 01:36 PM
  #45
My Feedback: (20)
Default Cobra Clone (Wing Ribs)
Wing ribs removed from their sheets, ready for assembly tonight. The main spars have been laminated as well. The design of the wing is interesting. Balsa spars with no sheer webbing or bracing. Probably shouldn't attempt any "blenders".
Old 04-23-2003, 12:59 PM
  #46
My Feedback: (20)
Default Cobra Clone (wing construction)
Began wing construction last night. I was checking the servo plates to make make sure my gear would fit, and discovered that I needed to enlarge the servo openings about 3/32" . Easier to do now before those plates get glued in! Here is were the construction is at now.
Old 05-06-2003, 10:06 AM
  #47
wagas's Avatar
Any Update Contemp?
Old 05-06-2003, 01:03 PM
  #48
My Feedback: (20)
Default Delays, delays, and more delays!
Sorry about the lapse. Haven't had much time to work on the Cobra. I have added the cap strips and leading edge sheeting to the bottom of the wing. I have also constructed the radio bay hatch and fit the servos. I will try and resume construction tommorrow. We had a nasty storm Friday afternoon (70 mph winds) and all day Saturday was spent cleaning up. Sunday was great weather...I went flying!
Old 12-04-2013, 04:41 AM
  #49
My Feedback: (46)
Constrictor's Avatar
Originally Posted by wagas
Pic 3
how much $$$ you askin?
Old 12-04-2013, 04:57 AM
  #50
My Feedback: (53)
Dansy's Avatar
Talk about reviving an old tread wish I could have another one with electric power.......that would be sweet.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
