Profile and Fun Flying Planes If you're a profile fan or into fun flyers than this is the forum to discuss those topics.
SuDoKhoi 60 Repair
Old 12-27-2002, 10:31 AM
Default SuDoKhoi 60 Repair
man paul....your really makeing some progress on that bird, you gonna recover the wings too....G
Old 12-28-2002, 01:46 AM
My Feedback: (45)
PaulSwany's Avatar
I'm probably going to fly it before I redo the wings.... For all you 60 size SoDo guys.... Did you to a thru bolt at the trailing edge of the wing or did you put blind nuts in?
Also... This SuDo had foam on the wing root plate.... Seems to make the wing fitment kinda spongy.... I'm thinking I'll nix the foam and cut a new dowel for the wing support. I think it should be pretty stiff when assembled... I shouldn't be able to flex the wings a bunch.
Old 12-28-2002, 02:48 AM
I use the bolt with a locknut on the other side.
Easy to get on and off.
My wings have stayed tight on the dowell with no problems.
Old 12-28-2002, 02:50 AM
My Feedback: (45)
PaulSwany's Avatar
Wayne - Do you have anything between the wing and fuse?
Old 12-28-2002, 02:54 AM
Nope.
The wings just butt up to the fuse.
Old 01-03-2003, 05:26 AM
  #31
My Feedback: (45)
PaulSwany's Avatar
Default Wings...
Check out these wings... See anything amiss?
Old 01-03-2003, 05:27 AM
  #32
My Feedback: (45)
PaulSwany's Avatar
The builder mounted the wing upside down......
Old 01-03-2003, 05:28 AM
  #33
My Feedback: (45)
PaulSwany's Avatar
I looked at the wings and they are a mess.. I tore the covering off one of them and it had been smashed a few times earlier.... I'm gonna junk the wings and get a wing kit from morris.....
Old 01-03-2003, 05:29 AM
  #34
My Feedback: (45)
PaulSwany's Avatar
Default Tail Feathers
Got the tail feathers mounted, covered and rigged...
Old 01-03-2003, 05:30 AM
  #35
My Feedback: (45)
PaulSwany's Avatar
Default pilot
My three boys are piloting this craft!!
Old 01-03-2003, 05:31 AM
  #36
My Feedback: (45)
PaulSwany's Avatar
Ulf - you got anymore of those pro-bro decals? I wanna put some big ones on the wings when I build 'em.
Old 01-03-2003, 05:34 AM
  #37
My Feedback: (45)
PaulSwany's Avatar
Default Business End
The business end of the SuDoKhoi with a ST 90.... Lottsa juice baybee!!
Old 01-03-2003, 01:34 PM
  #38
Hey Paul I got a bunch of the decals Ulf gave me...remind me and I'll give you some.....gator
Old 01-03-2003, 03:49 PM
  #39
Paul,
I just noticed something else he did wrong. The hatch for the fuse is on the wrong side.
I cant think of a reason that would make it matter. But in any case he did it wrong. LOL
Old 01-03-2003, 04:22 PM
  #40
I always say, if you can't be right, be consistent! <LOL>
Kevin
Old 01-03-2003, 04:27 PM
  #41
My Feedback: (45)
PaulSwany's Avatar
Damn.... Oh well... This ones turning out to be a project and a half..... Take a look at the motor mount beams... Do the look like they've been offset the wrong way? What did your's come out to Wayne?
Maybe I'll have to build an ecstasy after this....
Old 01-03-2003, 06:47 PM
  #42
My Feedback: (8)
m.gramling's Avatar
Paul,
you gonna put a moosecan on that ST90.
I should have my moosecan worked out on my ST90 by this time next week.
Old 01-03-2003, 06:49 PM
  #43
Paul,
The is no "thrust" offset in the motor beams. The beams are not centered on the fuse however.
If you are looking down at the top of the fuse with the nose pointing forward the beams are farther to the right. They are not centered on the fuse..
Old 01-03-2003, 08:32 PM
  #44
My Feedback: (45)
PaulSwany's Avatar
Wayne - weird about the beam offset... seams like they should be offset the other way... Do you have any right thrust in yours?
Michael - I might if I need the extra power...
Old 01-03-2003, 08:47 PM
  #45
Yeah I though the same thing as well. Probably wouldnt matter though.
I have one washer under each of the front motor bolts to give it some right thrust. Seems to be ok with that ammount.
Old 01-06-2003, 06:40 PM
  #46
My Feedback: (45)
PaulSwany's Avatar
Where is the CG supposed to be on this bird?
Old 01-06-2003, 07:06 PM
  #47
On the plans the CG has a rearmost point of the leading edge of the wing dowel. From there it is suggested as far as 2 inches forward of that point. That's the range given.
Old 01-06-2003, 07:07 PM
  #48
Paul.
The intructions have you put a doubler under the top piece of the forward section of the fuse just in front of the canopy. Then you are supposed to drill it so you can screw a hook in there for balancing. Is there a small hole in front of the fuse that looks like it may have been balanced that way?
I will measure mine today and let you know where it is just in case yours isnt done like this.
I flew mine yesterday. What a cool plane.
We got a pic of me catching it from a hover.
http://www.rcuniverse.com/showthread...&referrerid=60]
Old 01-06-2003, 07:12 PM
  #49
My Feedback: (45)
PaulSwany's Avatar
I checked the fuse... No small hole up there... bummer...
Awesome flight photo's Wayne!!! You are the man!!! You going to Houston for the ProBro Fly-In? I'd love to see you out there.
Old 01-06-2003, 07:26 PM
  #50
My Feedback: (45)
PaulSwany's Avatar
Did any of you guys use the stock landing gear? That stuff has got to weigh a ton!!! I'm think of making my own or drilling some holes in the stock gear.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
