SPA3D!!!!! This is cheatin........
A friend of mine built a spad 3d to play with. When he flew it, he called me up and said "This thing is a blast." He also said after 10 minutes with it he could hover and hairier with CONFIDENCE... I flew it the next day and MAN!!!! Its hovering with out a thought. I have flown and hovered many different types of 3D planes and this one is like cheating.
For all you newbies out there that want to learn, this is the plane for you...Heck I even built me one to play with. I have found that it doesent do much else but hovering, hariers, and tourque rolls. But, it will teach you the propper inputs... Shane |
RE: SPA3D!!!!! This is cheatin........
It'll do a lot more than hovering, harriers, and tourque
rolls. If not, then you haven't got it balanced/trimmed properly. Since my motor is old/weak, I get tail slides instead of torque rolls. One of the real benefits that I've seen is that it has really sharpened my usage of the rudder, something that is carrying over to my other planes. I used to understand the benefits of rudder usage but found it difficult to implement because by the time I thought about it, it was too late to do anything. Flying the SPA3D has made rudder usage much more instinctual. And, if you get tired of "... hovering, harriers, and tourque rolls", try flying it inverted. Live long, and prosper Jerry L. Gubka |
Inverted flight is a handful, but try inverted flat spins. My Sp3d is what taught me how to do them with my ucd 3d 46. You get real brave, cause its cheap. I can't seem to do anything with my rudder, and definitely not a knife-edge. It still won't hover, so I have to adjust some things.
I agree with Shanes300
It hovers and harriers well (probobly the best of any plane)...Torque rolls arnt that good b/c it wants to fall out on its back a little bit but they are "doable". The plane will also flat spin well...Its a good confidence builder for the hover and harrier but when you move on to something else dont expect to just jump right on the hover like you did with the spad. As far as rolling harriers, Knife Edge flight, and precision style 3D goes you can forget about it. It will harrier roll for a few rotations but I cant get it to sustain the roll for the full length of the field. I think harrier loops are all but impossible with this one as well (but I cant do them well to begin with so maybe I am off base on that one). I will say to go out and build yourself one. Its a lot of fun and a blast to fly. A great knock around airplane that will have you hovering inches off the ground within a few days of flying it (if you can sorta hover then it wont take but a few min to be Down on the deck.) Everything you hear about them is true, they really are the easiest plane to harrier and hover. |
Yeah aren't they cool !!
1 Attachment(s)
I know:D:)
They are a blast! I just enlarged one to 40" WS & length and installed a Magnum 65gp/se. Haven't flow it yet but I'll report on it later!:D
Ditto to all that. Great way to get the feel for the stalled flight!!!
I've got a SPA3D with a OS .46FX with a mousse can muffler spinning a 12.25x3.75 at 13,470 rpm. This thing will harrier until you get tired, flat spins, loops, roll and I can even get it to torque roll, but the rolls in the torque roll are so fast that you have no time to react to what is happening. I was the first at my field to have a SPA3D and it got so much attention. It won most unusal aircraft at our last fly-in. When people ask me about the SPA3D, I tell them it flys horribly, but hovers and harriers better than anything on the market today. The pucker factor is so low with this plane you really just don't care.
It is a great plane to play around with. |
I cant wait to get mine!!!!!!!!!!!!!!!!!!!!!!!!
Dan Im getting three for 35 so not that bad of a price =) |
I love my Spad3d. Unfortunately, coroplast isn't too condusive to the cold (below 30*). I had a dead stick, another result from the cold, and tried to get it back to the field and land. I came up short of the runway, but usually this isn't too bad of a problem. I didn't even break the motor mount this time, but the bottom part of the wing split back to front almost to the LE right at the middle. I will have to put a new piece of cp on it for the wing. The temp was about 15*, and the only reason I was flying is because I am addicted, but it was coooooooooooooooooooooold. [:-] Does the mouse can muffler give you that much of a boost or not really?
ORIGINAL: runover1 I love my Spad3d. Unfortunately, coroplast isn't too condusive to the cold (below 30*). I had a dead stick, another result from the cold, and tried to get it back to the field and land. I came up short of the runway, but usually this isn't too bad of a problem. I didn't even break the motor mount this time, but the bottom part of the wing split back to front almost to the LE right at the middle. I will have to put a new piece of cp on it for the wing. The temp was about 15*, and the only reason I was flying is because I am addicted, but it was coooooooooooooooooooooold. [:-] Does the mouse can muffler give you that much of a boost or not really? The performance difference is really really noticable. The first time I flew the SPA3D and the Super Stick with a mousse can I was literally yelling and shouting for joy in amazment. You have got to try one. I can't see spending $80 for a pipe that gives the same performance. If it gives that much power compared to the Mousse can. The mousse can may be a little stronger of a muffler than an aftermarket muffler. It isn't as pretty, but "who cares" is my motto. In the air it is the performance that counts for me. I am not knocking aftermarket tuned pipes. They have their place and the mousse can has it's. |
The MCP actually gives a better boost than a Pipe (for 3D). The effective range of the MCP is better, whereas the Pipe only gives a boost at the "tuned" RPM.
But I don't like the trouble of the MCP personally, and it's a bit pricey (Macs header, etc). I like the Tower muffler. Pretty close to the same performance and only $15. It's lighter than the stock but heavier than the MCP. I run the Tower muffler on all my 46fxs and the 50sx. Personally I like the 12x4 prop on both of these, but there is a wide grouping of props and we all have to find our own. |
1 Attachment(s)
ORIGINAL: Gordo-Outlaw The MCP actually gives a better boost than a Pipe (for 3D). The effective range of the MCP is better, whereas the Pipe only gives a boost at the "tuned" RPM. But I don't like the trouble of the MCP personally, and it's a bit pricey (Macs header, etc). I like the Tower muffler. Pretty close to the same performance and only $15. It's lighter than the stock but heavier than the MCP. I run the Tower muffler on all my 46fxs and the 50sx. Personally I like the 12x4 prop on both of these, but there is a wide grouping of props and we all have to find our own. $1.00 Mousse can $2.00 Aluminum pipe $2.00 RTV $1.50 Rod and bolt to hold the can together $6.50 total cost plus labor See below |
The can is very simple to make and gives very positive results. The Mac header version to me is the harder version to make.
Well there you go. Never saw that one before. I'll have to compare you results with those listed on Dave McD's site to see which is more effective. That is certainly easier and cheaper than the ones I did!!! Good on you!
How do you secure the aluminum tube?
thats aweosme...should i geta nice muffler for mine...im doing a TTPRO 46 or do I have the pwer needed...thnks guys
Dan |
1 Attachment(s)
ORIGINAL: runover1 How do you secure the aluminum tube? |
ORIGINAL: mAvRiCk thats aweosme...should i geta nice muffler for mine...im doing a TTPRO 46 or do I have the pwer needed...thnks guys Dan Have fun, BTW, I have my throws set up for barn doors. |
Thank you so much DTB! I guess I will have to buy some mousse now. Hmm, will it work on the dog? I wonder if you could use acetone or something to remove the paint on the outside, that way you would have a polished aluminum surface.
1 Attachment(s)
ORIGINAL: runover1 Thank you so much DTB! I guess I will have to buy some mousse now. Hmm, will it work on the dog? I wonder if you could use acetone or something to remove the paint on the outside, that way you would have a polished aluminum surface. Work on the dog? Here is a cheap photo of my MCP on my Super Stick |
you could use the mousse to make the dog look strung out. :D;)
ORIGINAL: Gordo-Outlaw The MCP actually gives a better boost than a Pipe (for 3D). The effective range of the MCP is better, whereas the Pipe only gives a boost at the "tuned" RPM. But I don't like the trouble of the MCP personally, and it's a bit pricey (Macs header, etc). I like the Tower muffler. Pretty close to the same performance and only $15. It's lighter than the stock but heavier than the MCP. I run the Tower muffler on all my 46fxs and the 50sx. Personally I like the 12x4 prop on both of these, but there is a wide grouping of props and we all have to find our own. |
1 Attachment(s)
ORIGINAL: runover1 I wonder if you could use acetone or something to remove the paint on the outside, that way you would have a polished aluminum surface. |
| All times are GMT -8. The time now is 09:19 PM. |
