Right Thrust?
I got a question For the TOPCAP pilots.
Anyone runing Right Thrust on the topcap? I was running 0 deg. But now i have the engine off i was thinking of Putting in some right? Good Idea? or Bad idea? Thanks Chris :confused: |
Right Thrust?
With my 46 FX no right thrust was required. When I switched to the Saito 72 it was mandatory. I added 1 washer..how ever many degrees that is.
Right Thrust?
Im asking because when i point the nose up it wants to pull left.
I also use a MDS 46 (dont laugh it runs good) Would right help me? I also notice most people are hovering the topcap alittle foward. It seems to me mine hovers better leaning back alittle. Any ideas? Later Chris |
Right Thrust?
chris, I always put 2 washers under the front to eng mounting holes, who knows I might could live without it. I just do it, give it a shot. Need to find somebody that can make some shems out of aluminum and buy them in bulk....Gator
Right Thrust?
I'd add some right thrust.
Right Thrust?
Had the same problem with my TopCap 2 washers under the front of each motor mount done the job.
Right Thrust?
You should start by adding about 2 degrees of right thrust, a washer or two on the front mounting bolts is what most guys use...
Right Thrust?
Just tried 1 washer today and it is not enough.
I guess ill add another tonight. Man I hate to take that engine Off again :( Later Chris |
Right Thrust?
If you can use some larger washers to cover more area because the little ones seem to just sink into the wood rails...
| All times are GMT -8. The time now is 04:30 PM. |
