Hinges on profiles
What are the preferred hinges on profile planes? CA type or the actual hinge type. I am assuming the hinge type because of less resistance with high throws.... The plane is a burrito and it will have digitals running the surfaces.
thanks |
RE: Hinges on profiles
radio south 1/4 scale CA hinges on my profiles !
Tip: I mark a line in the middle on both sides of the hinge with a crayon to keep the CA out of the center of the hinge. This keep the hinge flexible and prevents breaking from becoming to briddle if to much CA was used. |
I use those too... But I cut 'em in half....
Yep..Radio South CA hinges...Been using them for over 4 years with no problems, easy to slide in to a slot too...[8D]
One more for radio south, been using them for a few years, and like pauly I cut them in half.
| All times are GMT -8. The time now is 03:10 AM. |
