RCU Forums
-   Profile and Fun Flying Planes (https://www.rcuniverse.com/forum/profile-fun-flying-planes-105/)
-   -   pull pull tubes (https://www.rcuniverse.com/forum/profile-fun-flying-planes-105/2202303-pull-pull-tubes.html)
rcfunflyer 09-25-2004 05:17 PM
pull pull tubes
Anybody know a CHEAP source of pull pull tubes like the yellow ones that come in Morris kits? Do they have another name or use? I have the coated steel wire and fittings but can't find the tubes. Would prefer a local source. I found 1/8" tubing but that's too big.
depfife 09-25-2004 09:12 PM
RE: pull pull tubes
http://www.nyblimp.com/superior/PF.htm
Look at the plastic spaghetti tubing on the above site. I have never used it but here is a link to the thread where it was mentioned.
http://www.rcuniverse.com/forum/m_10...tm.htm#1033885
Eric
mikeboyd 10-18-2004 08:56 PM
RE: pull pull tubes
For the small fries, I have even used mixed drink straws for the fuselage exit and criss-crossed the pull-pulls. sullivan makes golden rod, plastic, light weight push rods that work as well a cables. I love them for throttle cables, since they are more flexible than solid steel. I have had several .40 sized planes that used one sixteenth music wire very successfully for pull-pull. Model Tech's magic series is a case in point. With solid wire, you don't need sheeves for the wire, just slots for the wire coming out at the back of the fuse.
