mojo 60 servos
I am building a mojo 60 and want some input on what servos to use. I was thinking of hitec 5625 for the tail 131 oz @6v and fairly fast. and hitec 635 for the ailerons 83 oz @ 6.0v. Any suggestions?
RE: mojo 60 servos
Sounds great. You should be happy with that. I have 635's on my elev and ailerons, and a 5945 on the rudder which is too much really considering it's not even sheeted, but that's all I had on the shelf when I built it.
RE: mojo 60 servos
keep us posted on the results
RE: mojo 60 servos
Sounds good to me... Should be a strong setup.
RE: mojo 60 servos
I've got Futaba S3010s on the wings and HS5925MGs on the tail and an HS81 on throttle, with a 5-cell pack so everything is way-fast.
5625s on the tail should be fine and 635s will be ample for the wings -- but don't be surprised if you bust a gear or two in those 635s if you cartwheel or give it too much hangar rash -- Karbonite is strong but very susceptible to sudden shocks. I don't use Karbonite-geared servos in any plane I expect to be dorking, nylon is "tougher" and metal is the best option. |
| All times are GMT -8. The time now is 06:40 PM. |
