JR 378 flaps?
Does any one know how to do flaps on a 378 so when the elevator goes up the alieron goes down? At the moment i am trying to do it with a y lead. i have 1 servo on each wing. i just want to have my loops really tight
JR 378 flaps?
On the other JR's you don't use the Y you turn on the flapperons and plug one aileron servo into the aileron and one into the aux port of the receiver. The throw on the flaps might need to be changed to a - value instead of a + to get them moving in the right direction. I have not had to mess with my set-up for a long time so I hope my memory is working . he he The info in the manual under flapperons should help explain it and show a diagram to help. Hope this helps I am at work or I would get a manual and try and help more. :D
How
No Y Or to know why.
You set your wing type for flaperon. You use the left ailron for the aileron port in the Rx and the right goes into Aux1 for flaps. You then program accordingly for reverse, throw etc. Danny at JR will be able to help you if you do not have the manual |
JR 378 flaps?
thanks alot you guys just done i cant wait to go flying now
| All times are GMT -8. The time now is 08:43 AM. |
