Go Back  RCU Forums > RC Airplanes > RC Jets > Turbine Clinic > PST Jets
PST J600R turbine radio specs >
PST Jets Direct support for PST Jets Turbines.
Old 04-15-2016, 06:32 PM
My Feedback: (27)
Default PST J600R turbine radio specs
Hi I have a PST J600R turbine. Everything I read in the manual is for older JR and Futaba radios. I'm looking for some specs for a Spektrum DX9 radio. I can get everything to work except the prime pump mode. Any help is greatly appreciated!!!!!! Thanks Mike
Old 04-23-2016, 04:08 AM
My Feedback: (27)
Is there no one out there that can help a new turbine owner out?????
Old 04-23-2016, 08:10 PM
You don't need any specs for a radio, just follow the radio setup in the manual, "stick up trim up" ect
Prime pump is not a function of the radio, you use it through the ground display unit.
Old 05-22-2016, 05:30 PM
My Feedback: (34)
Do you have a GDU for the tems unit?
Old 05-23-2016, 04:50 AM
My Feedback: (27)
Yes I have the GDU. I run through the start up process, everything seams to work. Except the prime pump mode. I checked to see if I'm getting any voltage at the pump. But no luck. Does that mean my gdu is bad?
Old 05-23-2016, 05:49 PM
My Feedback: (34)
Does the pump run? Simulate a start to seemifnthe pump runs if not bad pump
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
