Byton F-16 turbine mod
Hello all;
Have a Byron F-16 with Rossi .91/ducted fan setup and would like a turbine conversion done.
What turbine and mods should be done?
All suggestions/tricks/advice welcome.
Thank you in advance,
Harold Torres
Harold Torres
RE: Byton F-16 turbine mod
Hi Harold,
I've never seen the conversion 1st hand but I believe I have 2 local guys in Western Canada (1 for sure) that have done this mod with a J600R. I'll PM you an email address for a fellow by the name of Phil Meredith. Hopefully he can help you out and send you some details and photos...
Cheers!
Kelly
Cheers!
Kelly
FL
I think the best way to install a turbine in a Byron F-16 is a WREN in the tail cone. Less than two lbs weight with 14lbs thrust. No duct, not extra weight. Plane will balance easy with turbine hardware near nose.
I am planning that. Let me know.
Javier
Javier
FL
ORIGINAL: KC36330
That's not a Byron, looks like the stock setup for the SM.
kc
ORIGINAL: Javier-RCU
Take a look with a JetCat P60...
kc
My Feedback: (57)
Harold, muchacho no te rajes la cabeza y vuelalo con el Ducted Fan. Buscate una pista (como la de Hormigueros) que tenga la grama bajita, o sino vete a Sabana Seca y despegalo desde allĂ* en brea Ese avion no vale la pena ni el $$ convertirlo. Pero es muy divertido como Ducted Fan.
Saludos,
David
Saludos,
David
You are right, but catch the idea
kc
