Go Back  RCU Forums > RC Airplanes > RC Jets > Turbine Clinic > PST Jets
 Lengthening leads on the ECU? >
PST Jets Direct support for PST Jets Turbines.
Old 01-03-2009, 04:51 PM
My Feedback: (22)
LGM Graphix's Avatar
Default Lengthening leads on the ECU?
I'm installing all my equipment in my Super Bandit right now and I'm running into a snag with the start gas solenoid...
I don't have enough length on the wire to reach the ECU, I'm short by about 7" (of wire!)
Can I splice in extra wire on the solenoid to make it longer?
If the answer is YES, then:
Would it be better to add wire to the solenoid or the ECU lead?
Is it just a 2 wire system (there are 4 pins, that's why I ask).
Can I just use the same gauge wire to lengthen it or should I go up one wire gauge size bigger?
Thanks in advance!
Jeremy
Old 01-07-2009, 03:28 PM
My Feedback: (22)
Default RE: Lengthening leads on the ECU?
Man, viewed 22 times and no reply, thankfully Dean Wichmann gave me the answer I needed on the phone. Where are the PST guys???
Old 01-07-2009, 10:09 PM
Sorry for this late reply....
Its easier to lengthen the wire on the solenoid side. It is a 2-wires coupled to 4-pins connector.
Regards,
Kraivuth S
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
