Go Back  RCU Forums > RC Airplanes > RC Jets > Turbine Clinic > PST Jets
 CG for the Panther >
CG for the Panther
PST Jets Direct support for PST Jets Turbines.
CG for the Panther
Old 02-23-2009, 01:07 PM
My Feedback: (35)
Default CG for the Panther
I need the CG for the Panther. Also can you give me the throws in degrees. Dennis
Old 03-14-2009, 09:06 PM
Default RE: CG for the Panther
PM this info sometimes ago but for reference, here it is again:
Panther CG is 3.75 inches from the wing leading edge where the wing joins the fuselage. Make sure that you balance with gear down and empty main tank.
Elevator: 19mm Up/Down (16mm Low rate)
Aileron: 20mm Up/Down (17mm Low Rate)
Rudder: 15mm L/R
Flaps: T/O 25 Degree; Landing 45 Degree
Regards,
Kraivuth S.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
