Go Back  RCU Forums > RC Airplanes > RC Jets > Turbine Clinic > PST Jets
 Connections on PST 600r question >
PST Jets Direct support for PST Jets Turbines.
Old 03-14-2009, 04:09 PM
Default Connections on PST 600r question
Hello
I just bought a second hand pst j600r and are installing it into a falcon 1.20
but im wondering about some connections.
From the lower hole in the TEMS there are 4 cables coming out.
# 1 is for the rpm
# 2 is for reciver
# 3 is for gas valve
but nr 4 is a 2 wires cable and there is a red shrimpwrap on the connector.
What is that for, have read the instructions but cant find an answer.
Could it possible be for a fuel cutof valve??
Remy
Norway
Old 03-14-2009, 09:01 PM
Default RE: Connections on PST 600r question
Hi Remy,
The 4th wire is for Fuel Solenoid. You can use any standard 4mm 6V (Fail-Closed) solenoid valve that is designed to handle kerosene fluid. The TEMS will open this valve when the parameters for start and run are met.
Regards,
Kraivuth S.
Old 03-15-2009, 04:17 AM
Thanks for the quick answer
The Falcon is small so i wont use a electric fuel cutoff valve.
Regards
Remy
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
