Go Back  RCU Forums > RC Airplanes > RC Jets > Turbine Clinic > PST Jets
Reload this Page >
Reaction ARF Directive - Flight control seams
PST Jets Direct support for PST Jets Turbines.
Old 03-23-2009, 03:43 AM
B777
Default Reaction ARF Directive - Flight control seams
Subject: PST Composite Reaction ARF, Model airplane directive
One of the factory flown reaction exhibited a portion of the bottom of the elevator skin breaking off when flown aggressively. As a result, we would like all the owners of the RARF to inspect "ALL" the flying surfaces and perform the following:
Gently deflect the control surface (elevator, rudder, aileron, flap) and run a thin line of quality medium CA along the NON hinged line. This is where the composite skin contacts the wood, and let the glue run along the length of the joint. DO NOT use kicker, it will weaken the glue and generate unneeded heat. Make sure the glue is fully dried and check again for smooth deflection and proper glue flow. Perform this procedure to all the control surfaces.
You can also use high quality epoxy resin or Hysol for this task.
Although we have not seen any problems at the wings or tail group, we recommend that you do the same thing at the flying surface side where the skin contacts the wood on the wing aileron, wing flap, fin and stab area. Please see attached pictures.
Thanks and regards,
Kraivuth S.
PST Jets Thailand
ID:	1164041   Click image for larger version
ID:	1164042   Click image for larger version
ID:	1164043   Click image for larger version
ID:	1164044   Click image for larger version
ID:	1164045   Click image for larger version
ID:	1164046   Click image for larger version
