Go Back  RCU Forums > RC Airplanes > RC Jets > Turbine Clinic > PST Jets
 ecu temp reads backwards >
PST Jets Direct support for PST Jets Turbines.
Old 11-06-2009, 06:29 PM
Default ecu temp reads backwards
Hi
I also shorten the cables only from the motor side. I drew diagram for the temp plug when i turn on read 22c i put a hair dryer near the probe and the temp went neg to 0. I moved the wires to opposite sides and the temp now goes possitive the motor and tems cable are different each have a red wire one a white and the other (forgot) normal thinking you would think red to red and so on i am thinking tho every thing is ok now my wall thermometer reads 21 c and the tems 22 c . is there a way to change to f degrees ?
Arden
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
