Go Back  RCU Forums > RC Airplanes > RC Jets > Turbine Clinic > PST Jets
 pst 1300 fadec upgrade w/new rpm sensor >
PST Jets Direct support for PST Jets Turbines.
Old 12-19-2009, 02:37 PM
Default pst 1300 fadec upgrade w/new rpm sensor
I just got a new fadec from pst with a new rpm sensor. i am not sure i got the right one the one i got is curved with two rubber gromets. i was at Xicoy Electrónica web site and that one apears to be for the 600 the other one shown for larger motors is rectangular and apears to be for the 1300 how are they to be mounted with one screw or two and does the magnet face to the back or to the front of the turbine and also will the original rpm sensor work. also can I use the fuse and switch from the OLD tems WITH THE FADEC.
thanks
Arden
Old 12-19-2009, 08:26 PM
Default RE: pst 1300 fadec upgrade w/new rpm sensor
The RPM sensor is universal and it should be mounted with the curvature matching with the turbine inlet. Fuse and Switch are no longer needed with the Fadec since the main power is switched on with the Rx power. You can use the switch and fuse if you want to.
Cheers,
B777
Old 01-04-2010, 01:17 PM
My Feedback: (28)
tp777fo's Avatar
How much are the new ECU's for the 1300R?
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
