Q-40 Racing Discuss AMA 422 and any other variants of Quarter 40 racing
Build an Ashley MM
Old 04-02-2016, 12:36 PM
  #126
sahartman21
Default Build an Ashley MM
A rudder horn was made and installed. The pictures shows the basic steps.
ID:	2155638   Click image for larger version
ID:	2155639   Click image for larger version
ID:	2155640   Click image for larger version
ID:	2155641   Click image for larger version
ID:	2155642   Click image for larger version
ID:	2155643   Click image for larger version
ID:	2155644   Click image for larger version
ID:	2155646   Click image for larger version
ID:	2155647   Click image for larger version
ID:	2155648   Click image for larger version
ID:	2155649   Click image for larger version
ID:	2155650   Click image for larger version
Old 04-02-2016, 12:38 PM
  #127
sahartman21
The rudder pushrod was made and test fit.
The end at the servo will be glued on after the rudder is hinged.
ID:	2155652   Click image for larger version
ID:	2155653   Click image for larger version
ID:	2155654   Click image for larger version
ID:	2155655   Click image for larger version
Old 04-02-2016, 02:41 PM
  #128
sahartman21
The engine kill was made by bending a piece of wire around a 9/64" drill bit. Bend to allow an easy pull in the hole. Trim off the excess and file so the edge is not sharp.
The pictures show the process:
ID:	2155662   Click image for larger version
ID:	2155663   Click image for larger version
ID:	2155664   Click image for larger version
ID:	2155665   Click image for larger version
Old 04-03-2016, 12:06 PM
  #129
sahartman21
The rudder was cut loose, it was fitted, and CA hinges were installed.
ID:	2155756   Click image for larger version
ID:	2155757   Click image for larger version
ID:	2155758   Click image for larger version
ID:	2155759   Click image for larger version
ID:	2155760   Click image for larger version
Old 04-03-2016, 12:10 PM
  #130
sahartman21
The rudder horn was glued in place with medium CA.
The pushrod was installed and the pushrod end was attached with rubberized CA.
Make sure the surface is straight while the CA is drying.
ID:	2155762   Click image for larger version
ID:	2155763   Click image for larger version
Old 04-10-2016, 01:43 PM
  #131
sahartman21
A small amount of finishing epoxy was mixed and applied in the aileron grove. Excess was removed with a paper towel.
The purpose is to cover the foam that is exposed and reduce the likelihood that the paint will attack the foam.
ID:	2156660   Click image for larger version
Old 04-10-2016, 01:46 PM
  #132
sahartman21
Tape off areas you don't want painted.
ID:	2156662   Click image for larger version
Old 04-10-2016, 01:51 PM
  #133
sahartman21
Sand the surface of the model with 220 grit sandpaper. This will remove glue and other items from the finish.
It will also prepare the surface for the next few steps.
ID:	2156664   Click image for larger version
ID:	2156665   Click image for larger version
ID:	2156666   Click image for larger version
ID:	2156667   Click image for larger version
Old 04-10-2016, 01:54 PM
  #134
sahartman21
Any large holes should be addressed with polyester filler.
ID:	2156669   Click image for larger version
ID:	2156670   Click image for larger version
Old 04-10-2016, 01:57 PM
  #135
sahartman21
Some a spackle filler is made by adding a small amount of water until the filler is the consistency of mayonnaise.
The mix is rubbed into the surface to fill pinholes and small holes.
I set the model out of the way to dry.
ID:	2156672   Click image for larger version
ID:	2156673   Click image for larger version
ID:	2156674   Click image for larger version
Old 04-13-2016, 06:54 PM
  #136
sahartman21
The majority of the spackle was sanded off with 220 grit sandpaper.
I used a sanding block on the wing and stab.
The other surfaces were sanded without a block.
The intent is to leave spackle in the fiberglass weave and any small holes.
ID:	2157280   Click image for larger version
ID:	2157281   Click image for larger version
ID:	2157282   Click image for larger version
ID:	2157283   Click image for larger version
Old 04-14-2016, 04:44 PM
  #137
sahartman21
The models were primed with white KlassKote epoxy based primer.
This is a two part finish. It was reduced with one part epoxy thinner to one part primer.
Approximately 5 ounces of primer (prior to thinning) was used per model.
ID:	2157395   Click image for larger version
ID:	2157396   Click image for larger version
ID:	2157397   Click image for larger version
ID:	2157398   Click image for larger version
ID:	2157399   Click image for larger version
ID:	2157400   Click image for larger version
Old 04-16-2016, 11:45 AM
  #138
sahartman21
The primer was sanded smooth with 320 grit paper used dry.
For relatively smooth surfaces a block was used and other areas were sanded without a block.
Compressed air was used to clear the dust from the surface of the model.
ID:	2157626   Click image for larger version
ID:	2157627   Click image for larger version
ID:	2157628   Click image for larger version
ID:	2157629   Click image for larger version
Old 04-16-2016, 02:01 PM
  #139
sahartman21
Swift Red Acrylic Enamel paint was chosen for the finish. I used about 3.5 ounces of paint (prior to reducing) per model.
An inexpensive spray gun was used to apply the paint. Start with a light coat. Allow to dry a few minutes. Then apply more paint.
ID:	2157638   Click image for larger version
ID:	2157639   Click image for larger version
ID:	2157640   Click image for larger version
Old 04-17-2016, 01:59 PM
  #140
sahartman21
After about 24 hours the finish was wet sanded.
These steps remove imperfections and give the model a smooth finish.
ID:	2157806   Click image for larger version
Old 04-18-2016, 05:38 PM
  #141
sahartman21
I sprayed on a very light second coat. This time I used my larger spray gun. This time I was happy with the finish.
ID:	2157989   Click image for larger version
ID:	2157990   Click image for larger version
Old 04-21-2016, 09:40 AM
  #142
skooterII
Looking good Scott.
Old 04-22-2016, 05:16 PM
  #143
sahartman21
I wet sanded the surface to remove any dust reintroduced during painting.
ID:	2158488   Click image for larger version
ID:	2158489   Click image for larger version
ID:	2158490   Click image for larger version
Old 04-23-2016, 12:33 PM
  #144
sahartman21
The stencils were applied, stripes were masked, and rest of the model was covered.
ID:	2158652   Click image for larger version
ID:	2158653   Click image for larger version
ID:	2158654   Click image for larger version
ID:	2158655   Click image for larger version
ID:	2158656   Click image for larger version
ID:	2158657   Click image for larger version
ID:	2158658   Click image for larger version
Old 04-23-2016, 12:36 PM
  #145
sahartman21
A very light coat of spray paint was applied. After a few minutes an additional coat was applied.
ID:	2158660   Click image for larger version
ID:	2158661   Click image for larger version
Old 04-23-2016, 12:39 PM
  #146
sahartman21
I removed the stencils and masking tape just a few minutes after the surface was painted.
Here are the models so far. I will apply clear coat after waiting a few days,
ID:	2158663   Click image for larger version
ID:	2158664   Click image for larger version
Old 04-23-2016, 03:39 PM
  #147
sahartman21
The edges of the black trim were wet sanded for a smooth transition between the colors.
Old 04-25-2016, 06:44 PM
  #148
sahartman21
The wind calmed down and I sprayed the on the clear coat.
I used a type for spot panel work. It was mixed, thinned about 25%, and sprayed on. After just a few minutes the finish was dry to the touch.
ID:	2159186   Click image for larger version
ID:	2159187   Click image for larger version
Old 04-30-2016, 10:01 AM
  #149
sahartman21
I've begun the very important sanding and polishing steps.
The model was lightly sanded with 2000 grit wet and dry sandpaper that was used wet.
I followed with a medium cut cleaner and finished with a wax.
ID:	2160092   Click image for larger version
ID:	2160093   Click image for larger version
ID:	2160094   Click image for larger version
ID:	2160095   Click image for larger version
ID:	2160096   Click image for larger version
Old 04-30-2016, 01:36 PM
  #150
sahartman21
After a little polishing even my paint jobs look pretty good.
ID:	2160141   Click image for larger version
ID:	2160142   Click image for larger version
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
