Go Back  RCU Forums > RC Airplanes > Pylon Universe - RC Pylon Racing > Q-40 Racing
Reload this Page >
Build a Miss Ashley - Revisited
Q-40 Racing Discuss AMA 422 and any other variants of Quarter 40 racing
Old 12-18-2017, 05:59 PM
  #51
sahartman21
Default Build a Miss Ashley - Revisited
The center section of the wing was covered with plastic wrap in preparation for wing potting.
ID:	2248066   Click image for larger version
Old 12-18-2017, 06:01 PM
  #52
sahartman21
The wing saddle was sanded with some coarse sand paper to give the glue something to stick to.
ID:	2248068   Click image for larger version
Old 12-18-2017, 06:05 PM
  #53
sahartman21
Vaseline was applied to the outside of the metal hold down screws.
A mix of finishing epoxy and micro balloons was made. You need about 1/2 ounce of finishing epoxy per wing saddle.
The mix was dabbed on the wing saddle.
ID:	2248070   Click image for larger version
ID:	2248071   Click image for larger version
ID:	2248072   Click image for larger version
Old 12-18-2017, 06:10 PM
  #54
sahartman21
The wing was attached with the wing screws and the alignment was double checked.
Verify that the saddles are filled with the mix. I used my finger to smooth the area around the filet.
Clean any filler off the fuselage and other areas with rubbing alcohol.
Set the models out of the way to dry.
ID:	2248074   Click image for larger version
ID:	2248075   Click image for larger version
Old 12-20-2017, 03:00 PM
  #55
sahartman21
The wing was removed from the fuselage and the saddle was adjusted as needed.
A cutoff disk was used to trim the wing saddle and a sanding block was used to shape the outside.
ID:	2248197   Click image for larger version
ID:	2248198   Click image for larger version
ID:	2248199   Click image for larger version
ID:	2248200   Click image for larger version
Old 12-22-2017, 06:31 PM
  #56
sahartman21
The following pictures shows the installation of the Heavy Duty Strip Aileron horn set into the wing.
I begin by drilling holes through the wing for the horns.
The slot from the horn to the ailerons is about 1/8" wide. The slot in front of the ailerons is approximately 3/32" wide.
The ailerons start 6" from the wing center line. The ailerons are approximately 14" by 1 1/4" and the far tip remains connected to the wing.
ID:	2248405   Click image for larger version
ID:	2248406   Click image for larger version
ID:	2248407   Click image for larger version
ID:	2248408   Click image for larger version
ID:	2248409   Click image for larger version
Old 12-22-2017, 06:34 PM
  #57
sahartman21
A cutoff disk is used to cut through the fiberglass cloth that is between the foam and balsa sheeting.
This needs to be done in the area covered up by the torque rod.
ID:	2248411   Click image for larger version
Old 12-22-2017, 06:40 PM
  #58
sahartman21
The plastic outer sleeve should be sanded to insure that the glue will stick.
The heavy duty rods must be laid out and bent to shape.
A slot is cut to allow connection of the aileron to the torque rods.
ID:	2248413   Click image for larger version
ID:	2248414   Click image for larger version
ID:	2248415   Click image for larger version
ID:	2248416   Click image for larger version
Old 12-22-2017, 06:47 PM
  #59
sahartman21
I cut pieces of wood to cover areas where the glue should not go.
Some masking tape was placed over the exposed wood stop the glue from sticking to the surface.
A mix of finishing epoxy and micro-balloons was made to the consistency of thin toothpaste. It filled the slots where the torque tubes were routed.
I recommend overly filling the hole as it is common for the glue to settle.
Set the wings level and in a warm area to insure the epoxy will dry.
ID:	2248418   Click image for larger version
ID:	2248419   Click image for larger version
ID:	2248420   Click image for larger version
ID:	2248421   Click image for larger version
ID:	2248422   Click image for larger version
Old 12-23-2017, 09:39 AM
  #60
sahartman21
A scraper blade was used to bring the surface flush with the wing.
ID:	2248488   Click image for larger version
ID:	2248489   Click image for larger version
ID:	2248490   Click image for larger version
ID:	2248491   Click image for larger version
Old 12-23-2017, 03:45 PM
  #61
sahartman21
The gear were prepared for installation.
The plates are tapped for three 10-24 flat head nylon bolts.
ID:	2248520   Click image for larger version
ID:	2248521   Click image for larger version
ID:	2248522   Click image for larger version
ID:	2248523   Click image for larger version
ID:	2248524   Click image for larger version
ID:	2248525   Click image for larger version
ID:	2248526   Click image for larger version
Old 12-23-2017, 03:49 PM
  #62
sahartman21
Petroleum jelly was spread over the gear reduce the likelihood of sticking.
A mix of finishing epoxy and micro-balloons was applied to fit the gear to the wing.
ID:	2248528   Click image for larger version
ID:	2248529   Click image for larger version
Old 12-24-2017, 06:12 PM
  #63
sahartman21
A scrapper blade was used to scrape the epoxy mix flush with the wing.
I followed by using a model knife around the edge to insure a clean break.
Gently remove each gear and finish cleanup as required.
Identify each gear with a number to insure that they will fit properly.
ID:	2248617   Click image for larger version
ID:	2248618   Click image for larger version
ID:	2248619   Click image for larger version
Old 12-26-2017, 05:43 PM
  #64
sahartman21
I used the time-proven method of using dowel rods to install the aileron servo.
This involves locating the servo and installing pieces of 3/8" diameter rod into the wing.
The pieces of dowel rod were glued in place with 30 minute epoxy.
ID:	2248841   Click image for larger version
ID:	2248842   Click image for larger version
ID:	2248843   Click image for larger version
ID:	2248844   Click image for larger version
ID:	2248845   Click image for larger version
ID:	2248846   Click image for larger version
ID:	2248847   Click image for larger version
Old 12-26-2017, 05:48 PM
  #65
sahartman21
I've found that approximately 1 1/4" of clearance is needed to insure that the aileron servo and horns don't touch the pushrods.
ID:	2248849   Click image for larger version
Old 12-26-2017, 05:52 PM
  #66
sahartman21
I copied my earlier servo installation by making a pattern of the servo tray and following the installation.
Shoe Goo is my preferred adhesive for installing the servo tray.
Attached Thumbnails 2017 Ashley Servo Tray.pdf   Click image for larger version
ID:	2248852   Click image for larger version
ID:	2248853   Click image for larger version
ID:	2248854   Click image for larger version
ID:	2248855   Click image for larger version
ID:	2248856   Click image for larger version
Old 12-30-2017, 02:31 PM
  #67
sahartman21
I am going to try out a stabilizing receiver.
The process begins by installing a firm level tray in the fuselage for the installation of the receiver.
Shoe Goo works great in this service to attach the tray.
ID:	2249307   Click image for larger version
ID:	2249308   Click image for larger version
ID:	2249309   Click image for larger version
ID:	2249310   Click image for larger version
Old 12-30-2017, 02:37 PM
  #68
sahartman21
I was told that a stabilizing receiver requires a firm connection to the fuselage.
My installation attaches the receiver to the secondary tray with the provided double sided tape.
Servo screws hold the secondary tray to the horizontal plate.
The screws are backed out if you need to remove the receiver.
ID:	2249312   Click image for larger version
ID:	2249313   Click image for larger version
ID:	2249314   Click image for larger version
ID:	2249315   Click image for larger version
ID:	2249316   Click image for larger version
Old 12-30-2017, 02:41 PM
  #69
sahartman21
The receiver battery pack should be located back behind the servos to aid in balancing the model.
A Velcro type connector was used to attach the battery.
ID:	2249318   Click image for larger version
Old 12-31-2017, 04:00 PM
  #70
sahartman21
The landing gears were installed and verified to be in the appropriate locations.
The CG is approximately 3 3/4" to 3 7/8" back from the leading edge of the wing.
The gear axel should be about 3/4" in front of the CG.
If the model bounces on landing try moving the axel back. If the model noses over try moving the gear forward.
ID:	2249425   Click image for larger version
Old 01-01-2018, 11:44 AM
  #71
sahartman21
Antenna tubes were glued in place with Shoe Goo.
ID:	2249623   Click image for larger version
ID:	2249624   Click image for larger version
Old 01-14-2018, 05:24 PM
  #72
sahartman21
The following pictures show how the slot was identified in my earlier construction thread.
  • The incidence on the wing is adjusted until the meter reads level.
  • I then drew a line on the top section of the tail based upon a bubble level.
  • A cutoff wheel was used to cut the slot for the tail.
ID:	2251133   Click image for larger version
ID:	2251134   Click image for larger version
ID:	2251135   Click image for larger version
ID:	2251136   Click image for larger version
Old 01-14-2018, 05:33 PM
  #73
sahartman21
For this next group of 4 Miss Ashley's a jig was made for the tail alignment.
  • Some plastic wrap was placed over an earlier model's tail.
  • Multiple layers of fiberglass cloth and epoxy resin were applied.
  • After the resin dried the jig was trimmed as desired.
ID:	2251139   Click image for larger version
ID:	2251140   Click image for larger version
ID:	2251141   Click image for larger version
ID:	2251142   Click image for larger version
Old 01-14-2018, 05:37 PM
  #74
sahartman21
The jig was slipped over the tail surface and the cut was scratched in place with a model knife.
A red marker was rubbed over the scratch to further identify the cut marks.
ID:	2251159   Click image for larger version
ID:	2251160   Click image for larger version
ID:	2251161   Click image for larger version
Old 01-14-2018, 05:43 PM
  #75
sahartman21
The slot was cut with a cutoff disk.
Initially cut the slot narrow and gradually adjust it to fit.
Verify that the stabilizer is level with the wing.
ID:	2251174   Click image for larger version
