Steel Balls
MN
Steel Balls
Not really sure why I'm posting this, but I saw something at the winterfest this past weekend that I had never seen before. Not one, but a couple fliers that would hand start their Nelsons. Your definately not going to see me do this, but I was impressed.
Whats your thoughts....?
RE: Steel Balls
Tis amazing watching that sequence, isn't it. Over the past year I've been fortunate enough to be around a couple of those "Old U-Control Guys" during practice and local races. I always have a slight cringe watching till there Nelson(Opps, or Jett) is humming on the first or second flip. Personally I think there is still a certain lingering "U-Control" dizziness on going here. Just kidding J.W. and B.C. Can't tell ya how much I've learned from those folks in a very short time.
Tom Hegland
37c
Tom Hegland
37c
RE: Steel Balls
There is an ex speed control line guy at my club that starts his nelson with a finger flip from time to time. I don't have any qualms starting my sport engines that way... but I do not want to stick my hand into a ghinsu knife prop set to start at full throttle... unless my starter fails at the line.
RE: Steel Balls
I know both Bruce and Jacob that do that. They both finger start their Jetts within one to two flips on it. [sm=surprised.gif]
They make it seem easy, but my concern is safety for myself. Jacob was trying to get me to do it also because he said it was easier, but No Way Jose! Not in a million year when the engine start of at full throttle.
RE: Steel Balls
Hi,
No Problem. The start is all in how you prime the engine. I have found if you shut the engine off with the carb it will generally leave a nice prime in it. It will usually start within 1 or 2 flips. I think it may be easier on the bearings and the other moving parts inside.
When I first tried it I was scared, but now I actually think it is pretty easy, you just have to have confidence.
Jacob
Jacob
CA
RE: Steel Balls
i cherish my fingers. The people who are missing them once said the same things about how easy they are to flip. That what starters are for. I cherish my fingers.
RE: Steel Balls
The thing for you guys to remember is that your not flipping the engine through compression. Your bouncing the prop "backward" against compression, thus only touching the front side of the prop (which is dull). And Jacob is right... it all comes down to the prime.
Been doing it for 6 years..
Randy Bridge
Randy Bridge
RE: Steel Balls
Out of curiosity.... can you just flip it backwards using the spinner? Does it really save that much wear and tear on the bearings to make this an RPM gainer/maintainer? Thanks.
Dan
Dan
RE: Steel Balls
As far as saving wear and tear ... who knows? I doubt it. We start Q40 and FAI with starters, and those engines turn more rpm, especially FAI... up over 28K...
Rb
Rb
