New Q-500 Racer
New Q-500 Racer
Hi All,
I have just completed construction on a MadDog Q-500 Racer, the engine is a Rossi 23R40 and using the black minipipe at this stage. First Test Flight was scheduled for today but was postponed to next week.
Here are some photos.
Regards
Werner...
Regards
Werner...
MN
RE: New Q-500 Racer
Looks good, the Mad Dog is a great flying plane. Just curious, what is that Red circle behind the prop? If its a plastic spinner backplate, I'd get rid of it. Put a simple aluminum prop nut on there. Fox makes a nice one, so does Dubro, and also Darrol Cady at www.darrolcady.com
Is that pipe supported anywhere?
Let us know how the flight goes.
MN
RE: New Q-500 Racer
Here is a picture of the Cady Spinner. He has them in both 5/16" x 24 or 1/4" x 28 threads.
I'm not sure what the Rossi has, but I would bet its the 1/4 x 28.
Heres a picture.
Heres a picture.
RE: New Q-500 Racer
daven,
Thanks for the response, i will remove the spinner and get the prop nut, what is the reason that you would not put the spinner on.
Yes the Pipe is supported just out of sight between the landing gear with a aluminum support.
I will let you know when it flies...
werner
werner
