Spinner for Q500- Faster or not?
MN
RE: Spinner for Q500- Faster or not?
I like the spinner nuts that are sold at www.darrolcady.com
Work well for me in both 428 and 424 classes.
Bill,
There is no solid data to prove one is better than the other. Maybe some theories out there. I run the Tru-Turn 7/8" diameter spinner nut. Lots of guys in Florida run the little Jett spinners.
Randy Bridge
Randy Bridge
ORIGINAL: BadBill
Whats best for Q500? I have some folks telling me that a spinner is best ( which is my belief, but heck I don't know ) and others just telling me a spinner nut or a large acorn type. Anyone got any facts?
This data is what I gathered from my test with my BSE quickie Jett engine. Your result may vary with different engine's.
ORIGINAL: SSAN
It's best to use spinner nut over aluminum spinner.
Please elaborate, I don't understand this. Do you mean aluminum spinner over a spinner nut?
My Feedback: (7)
Mac,
Pardon me for jumping in here but I think by "over", he meant "instead of" rather than "on top of".
Generally, it's better to have less rotating mass up front, and less wetted area. About all the spinner does for you is clean up the flow around the propeller hub -- which is a good thing, all else being equal, but to get to the point of doing any good in that department, you've got to make the spinner so large that on a Q500 (which is required to have an exposed engine, no cowl) the boat-tail drag behind the spinner backplate starts to slow you down.
But Randy's right, there are no studies that prove this one way or the other. My suggestion? Put a big spinner on it and fly a tight course so you win your heats. Then everybody else will be crying in their beer because they don't have the "hot setup."
Duane Gall
RCPRO
Duane Gall
RCPRO
ORIGINAL: Mac Hodges
