Viper wheels
Viper wheels
The general advice on Viper wheels appears to be to throw them away as soon as possible.
Has anyone found a way of keeping the wheels on the axles?
Does silicone work?
Does anyone know of a commercially available axle that fit the Viper wheels?
Any comments will be most appreciated.
Does silicone work?
My Feedback: (7)
CA
RE: Viper wheels
I had some luck using thin Ca. which lasted about 20 flights. Next I tried epoxy after roughing up the brass bearing and wheel, lasted another 20 flights, before they flew off. Some guys just thru bolt them with nuts on both sides of the landing gear. If you are looking for the cleanest installation, buy a pair of wheels and the axles from Darrel Cady, about $15, and no more worries. Think you can get just the axles from him, but you will have to drill out the viper wheels.
NC
RE: Viper wheels
Just throw them away, it's the best thing. You will eventually bounce them off and most likely damage the gear and rip off the gear plate. Contact Mac or Bill at Hodges Hobbies and let them set you up with a new pair of racing wheels that come with a very good and strong axle assembly. They will last longer than the plane and cost around $12 bucks. You can put them on your next plane after you trash this one.
RE: Viper wheels
I'm new to the whole Pylon scene, having helped with NEPRO last season as a judge. I've recently bought a VIPER, and reading all the posts / my time at NEPRO, I learned two things: New wheels and a bladder tank.
Question is - have I forgotten any of the biggies?
I was going to order those two from Jett, and we thinking about their CG Tank.
As for the radio, I was going to sure a HITEC 555 for the receiver, a HITEC HS55 for the throttle, and Tower standard servos for the rest. The kit instructions suggest a 250mA battery pack, but I was think of building on out of 780mA AAA rechargeables. NEPRO mandates the TT40 for the engine.
Any suggestions?
Thanks, Mike
Any suggestions?
Thanks, Mike
MN
RE: Viper wheels
Mike, I am not sure the CG tank will fit in the viper. It is really designed for use in Q40.
I personally don't think the Hitec 55 will last on your throttle. Just a little too much vibration, go with the Hitec 85, or 80 at the minimum.
We've used 250 mah NICD's for years, so that would work, but I've switched to either 500 mah Nimhs or 720 mah Nimhs. Same weight as the 250 Nicd's but significantly more juice.
Good Luck.
Good Luck.
RE: Viper wheels
Dave,
I thought the CG tank would be wide. What about the standard with a 2" diameter? Mount it at the CG under the wing or foward just behind the firewall?
As for the HS-55, what I understand you're saying is that the servo will fail due to engine induced vibration alone the throttle linkage? Has there history of that?
Mike
Mike
WI
RE: Viper wheels
Well Mike I used 81's on my throttlefor a while and I would be lucky if they lasted a whole season... They're just not heavy enough. The 85, as Dave mentioned, seem to last pretty well. The 2" round tank will be fine in the viper, just get it as close to the CG as possible.
RE: Viper wheels
Lee,
For a throttle servo, would a Futaba FP-S133 work? I ask because I have a few in another plane.
Any other suggestions?
Thanks for the help, Mike
My Feedback: (14)
RE: Viper wheels
About the wheels-
I fly of of a grass field so on my Scat Cat I just took the gear off completely. Hand launch and belly land. I don't race it except with whoever wants to race at the field that day... You would have to mount your engine upright to make that work...
270
270
WI
RE: Viper wheels
Mike, I'm not familiar with that servo so I can't tell ya.... I would suggest biting the bullet and spending the $25 on an HS-85MG but that's just me.
ND
RE: Viper wheels
After reading the thread I went a head and ordered up a set of Jett Engineering wheels. I wasn't thrilled with the way the ones in the kit went on. I haven't flown the plane yet but now I'll feel better knowing that the wheels will be there when I want to land.
The new wheels are great, you can still use the bevel head screws that came with the kit.
