90-120 size q500
90-120 size q500
I am thinking about building a larger q500 just for fun.
I am looking at about a 65 inch wing, 13 inch cord, about 850 squares. I am guessing this to be about 30% over a stadard racer. If so, the fuse should be around 54 inchecs long if I pull straight from existing airframes.
As I would like to retain the wing dimensions, would this fuse length be acceptable?
How much area would be required for the v tail per half? What is the most favorite angle for the vtail? Dimensions on this would be nice.
Any comments would be appreciated.
DD
DD
My Feedback: (15)
RE: 90-120 size q500
I did this same idea with a Modeltech Joss Stick, back when they sold them as "almost-ready-to-cover" instead of today's covered ARFs. I even made it a V-tail, and it looked to have about the right dimensions compared to a real Q500. I flew it with a 1.08. It was fun for a few flights, then I sold it.
Kurt Bozarth
Kurt Bozarth
CA
Why don't you check out the Lanier Dominator 1500. It is a larger q500 style plane. Used in the large scale pylon races. Might be interesting or at least give you a guideline.
Thanks, I looked the Dominator 1500. Too big and heavy for me. I guess what I really want to know is can I take the dimensions from a standard size plane and blow them up to my requirements and still have a use-able platform?
Or a simpler way of asking, does everything stay proportionate?
